Recordings fuzzy for a split second
Every 20-30 seconds or so, the recording seems to get a bit fuzzy for a split second. I am pretty sure it is part of the recording since it is happening at the same places when I back up to re-wind. This happens on different shows.
Any ideas?
Have you tried viewing them with VLC?
Remote or At home?
TVE or from an HDHR?
Viewing with what client?
Watching via my AppleTV, directly connected to my computer via Ethernet, recording from antenna (not sure about TVE yet), on the Channels app on AppleTV.
Try using VLC to view one of the problem recordings. If fuzzy there, then it's the recording.
Good idea. Just did and from the short time I watched it, no fuzziness.
I just changed the streaming quality to Original and I think that helps.
I was on 1080 before.
