Please consider adding option to default passes for delayed start, or at least custom. I find myself having to add 30 seconds late to most of my passes start times. It would also be nice to automatically set the end padding to mirror the start padding by default, with an option to change after if needed.
If you want it bad enough, you can do it with command line curl while you're waiting for it to be implemented.
