The Tonight Show for example. NBC says it starts at 11:34:30. Channels starts recording at 11:34, but the show isn't actually starting until 11:35:30ish. So I get 1 min of the news before the Tonight show. I have several shows where this kind of thing happens. This is TVE and I might have read that this is the cause of the issue.
I want to start the tonight show 1 min late. Personally, I've never come across a show that starts early, but many many that start late. Why isn't there an option to start late when padding?
MCEBuddy strips out the minute when it processes it, but in Channels comskip leaves that min in as show.
On another note, I watch in Edge on windows. If I pause a show it will unpause itself at some point. There is no consistent time of how long it takes. I've been in the other room and it's unpaused, had the browser minimized and it unpauses. I've now gotten in the habit of just stopping the show instead of pausing.
One more, the browser player size. it's either full screen or the size of a post card. I tend to split my monitor between multiple windows. If I do this the video is really small. I can make it full screen, but then I cant use an other windows. I haven't seen any other player that work like this. Am I missing an option somewhere?
EDIT: feature has been added! (2021.04.30.1941)
"Hi,
I've added the ability to set negative padding on the web UI under the advanced editor for passes. This is available in the latest pre-release.
To update, please click the dropdown icon next to Check for Update on your DVR web UI settings page, then select Prerelease .
Aman K"
