All of my recordings are starting early. All of my settings are correct and havent changed anything. Any thoughts?
Make sure your DVR server has the correct time set.
If you can set a NTP time server for it, try time.google.com
And if your server has a browser, check its time using https://time.is/
Time.is
Your time is exact!
The difference from Time.is was +0.013 seconds (±0.019 seconds).
Support -> Troubleshooting will also tell you if the time of your DVR is correct.
I think this was the problem! I’ll run a check.
