Recordings still there, but not visible in UI
Sorry if this is common knowledge but the Shield had a major meltdown tonight and deleted Channels DVR and the Server. Managed to get it all back up and running but my recordings and passes aren’t showing up, what have I done wrong?
I can see the recordings on the external hard drive, and I’ve pointed the DVR to the folder so that I can see all the TV show named folders below it (along with a folder called Database) - is this correct? This won’t solve my passes problem though, not sure how to get them back. Any help appreciated!
You have to open http://x.x.x.x:8089/restore after reinstall and pick the latest backup from your Database directory
Thank you! Seems I have a few different Database folders but found it in the end!
