Recordings Storage Location
Hello,
I have my Channels DVR server running from a 4TB external HDD connected to a RPi 4. I am running out of storage space on the 4TB HDD. I was wondering if I could change where shows were saved to, such as a network share, or if there was a way to copy everything, including the Channels DVR install files and recordings, to another HDD that is bigger?
Also:
Thank you, but what about the files and everything that make Channels DVR work and function? How would I move those over from the old HDD to the new one?
If you're only adding a second drive, you don't need to do anything.
If you are doing a whole new installation, then:
