Recurring Errors on Recording
Using Nvidia Shield with Locast and Philo and getting these errors on a regular basis:
2021/05/27 21:05:59.985211 [DVR] Error running job 1622163600-25 Grey's Anatomy: could not start stream on channels=[7.1]: Locast: Get "https://api.locastnet.org/api/watch/station/114/40.800/-73.970": dial tcp: lookup api.locastnet.org: No address associated with hostname
2021/05/27 21:05:59.995234 [DVR] Starting job 1622163600-23 Law & Order: Special Victims Unit on ch=[4.1]
2021/05/27 21:05:59.997149 [ERR] Failed to start stream on channel 4.1 via LOCAST-501: Locast: Get "https://api.locastnet.org/api/watch/station/106/40.800/-73.970": dial tcp: lookup api.locastnet.org: No address associated with hostname
2021/05/27 21:05:59.997237 [DVR] Error running job 1622163600-23 Law & Order: Special Victims Unit: could not start stream on channels=[4.1]: Locast: Get "https://api.locastnet.org/api/watch/station/106/40.800/-73.970": dial tcp: lookup api.locastnet.org: No address associated with hostname
2021/05/27 21:05:59.997296 [DVR] Starting job 1622163600-25 Grey's Anatomy on ch=[7.1]
2021/05/27 21:05:59.997326 [DVR] Waiting 54m0.002681395s until next job 1622167200-53 Law & Order: Organized Crime
2021/05/27 21:05:59.999471 [ERR] Failed to start stream on channel 7.1 via LOCAST-501: Locast: Get "https://api.locastnet.org/api/watch/station/114/40.800/-73.970": dial tcp: lookup api.locastnet.org: No address associated with hostname
2021/05/27 21:05:59.999540 [DVR] Error running job 1622163600-25 Grey's Anatomy: could not start stream on channels=[7.1]: Locast: Get "https://api.locastnet.org/api/watch/station/114/40.800/-73.970": dial tcp: lookup api.locastnet.org: No address associated with hostname
Does anyone know what is causing this?
DNS configuration issue
Any suggestions on how to fix this?
Check and fix your dns settings
Which settings are you talking about? The only setting I'm aware of is the IP address of the DNS server. I don't have any problems with other programs that use DNS.
Not sure what you tell you. The DNS server you're using is not returning returning results for the Locast server. Your only option is to use a different dns server. You can try 8.8.8.8 or 1.1.1.1. Or you could reboot your router and hope that fixes the dns server there.
Thanks @tmm1. I will try that.
