Refinement of Recording Options
I frequently set up recording of episodes or passes for EPL (English Premier League) matches using Channels - and I find that when I look at the scheduled recordings listing - it correctly picks up the games I am interested in - BUT, often the games are broadcast on more than one channel - e.g. NBCSn in English; and also TeleMundo in Spanish - so I either have to manually go back and eliminate the one I don't need from the recording listing or have it recorded twice that can consume a second tuner unnecessarily (possibly preventing something else from being recorded (exceeding tuner capacity).
I have added a screenshot to show example - in this case I'd like to eliminate the channel 1047 recording entry always, but use the channel 1207 for recording ( or the other way round if preferred)
Is the a way to consider adding the ability to further filter the scheduled recording for passes - to eliminate unnecessary channels from the projected recording schedule - so that it never appears on the scheduled recording listing an avoid the above issue?
Many thanks in advance - happy to provide further info/ clarity as needed
With the web interface you can specify the channel. (And a number of other refinements.)
