Refresh Sources Question
I usually do this via the computer that is running the DVR server…but I usually watch my channels on my iPad. I am trying to refresh the sources from IPAD and it doesn’t do anything. Is there a way to refresh other than going to the computer?
You can load the DVR web UI on your ipad in Safari
How exactly do I do that? Sorry for such a dumb question.
Open the Safari web browser and go to http://my.channelsdvr.net
That only works if you have remote access enabled.
If you are on your home network, you can always visit http://DVR_IP:8089.
http://192.168.1.3:8089
If you know the name of the computer running the DVR server, you might also be able to access it by name, eg:
htttp://servername:8089
or possibly:
http://servername.local:8089
or some variation of the above. Sort of depends on how your router has been setup to handle local names.
