Reinstall Channels Docker Problems
I use Unraid. I have the channelsdvr docker installed. Recently I was upgrading the NAS. I had an issue and ended up reinstalling the channels docker. Here are my problems
  1. I ended up with two recording paths. I figured this out because I started getting "play back failed".
Here are the paths
\share\dvr
\share\dvr\dvr
It looks like some recordings are now suppose to be in \share\dvr\tv\ and some need to be in \share\dvr\dvr\tv. How can I combine the folders and fix this issue?
Move all the folders from /share/dvr/dvr to /share/dvr ?
I moved all the folder but it doesn't seem to fix the playback failed. I believe some of the recordings are linked to \dvr\dvr\tv and some are linked to \dvr\tv
Is there a way to combine all the folders and then link the recordings properly?
I looked closer ar my share setting in the docker. I adjusted it and everything seems happy
Glas to hear you sorted it out.
I did something similar when I moved my DVR recording directory in a Docker Container.
I had one path that was all UPPERCASE and another that was all lowercase.
Found out Linux was CaSe sensitive the hard way.
