I know that sometimes you post updates in the DVR forum with release notes / bug fixes of what’s in the beta versions that you can acquire by shift-updating. Are there any similar release notes for the Android TV beta versions hiding anywhere?
Beta versions of the Android TV app are uploaded with release notes so they should be visible in the Play Store
Can you toggle between beta branches and release branches? Or is it like a gang – if you’re in it, you’re in it for life?
Yes you can opt-in and out via the Play Store
