Hey all: I need some advice setting up remote DVR access. I'd like to try to set it up using a DMZ rather than bridge mode first, if that's at all possible.
Here's my network topology. All connections are wired ethernet.
WAN --> xFi Gateway --> Google Router (WAN IP: 10.0.0.66, LAN IP: 192.168.86.1) --> DVR (Synology NAS) (192.168.86.102)
In the xFi Gateway app, advanced settings:
In DMZ, I've set DMZ Status: Enabled; IP address: 10.0.0.66.
In Port Forwarding I've set Reserved IP address: 10.0.0.66; Port Number 8089; Protocol: TCP
In the Google Home app, Advanced Settings:
- IP Reservations: DVR: 192.168.86.102
- Port Management: 192.168.86.102; 8089-->8089; TCP (I don't really understand what the from/to port is for?)
Problem:
In the Channels DVR Server Troubleshooting screen it shows this error for remote DVR:
Outgoing connections are coming from {my xfinity WAN IP address} but the external IP of the router is 10.0.0.66.
What am I doing wrong? Any suggestions?
