DVR access failure help me please! The request timed out.
Probably need more information. Start with rebooting your DVR, and closing out your iOS/ tvOS clients and trying again after the server reboots.
Can you get to the DVR web page?
Sounds like this belongs in a new post
Ive done all the things you said and still have the same problem ive reset it and it started happening ever since the last update. Before the update it would work fine, it works with only using the internet but with the app thats where it doesnt work, what can i do to fix it?
Which update are you referring to?
Check to make sure that bonjour is check makes on the web interface.
The last beta update
On the DVR, tvOS, iOS. Roku? I’m sorry but you aren’t exactly providing much data, or answering quesrions. Maybe someone else can read minds.
Our resident mind reader is hopefully on his way to Bali!
