Having trouble accessing remotely. I first setup port forwarding with 8089 and that worked great (except for the lack of security) so I turned on “Enable remote access” which I assume turns on a secure interface on 8090. The log shows “2017/03/12 19:30:29 [NAT] Successfully mapped port 8090 using natpmp” but if I try to access 8090 either locally or remotely it just hangs. Any ideas?
Checking the box is unnecessary if you have already setup port forwarding.
Security login is presented if you’re not on local network and not logged into your community account. Try a private browsing tab over LTE.
Ah OK thanks I’ll try that. Sorry for all the questions - it’s the basketball
