Remote access
Can you post any error message from the Log tab about upnp or natpmp? Thanks.
2017/01/11 15:58:37 [SYS] Starting Channels DVR v2017.01.10.0517 (linux-x86_64)
2017/01/11 15:58:38 [HDR] Found 2 devices
2017/01/11 15:58:38 [ERR] bonjour: Failed to bind to udp6 port: listen udp6 [ff02::]:5353: socket: address family not supported by protocol
2017/01/11 15:58:38 [SYS] Bonjour service running for dvr-qnap.local. [192.168.1.103]
2017/01/11 15:58:38 [SYS] Started HTTP Server
2017/01/11 17:18:13 [SYS] Shutting down…
2017/01/11 17:18:19 [SYS] Starting Channels DVR v2017.01.10.0517 (linux-x86_64)
2017/01/11 17:18:20 [HDR] Found 2 devices
2017/01/11 17:18:20 [ERR] bonjour: Failed to bind to udp6 port: listen udp6 [ff02::]:5353: socket: address family not supported by protocol
2017/01/11 17:18:20 [SYS] Bonjour service running for dvr-qnap.local. [192.168.1.103]
2017/01/11 17:18:20 [SYS] Started HTTP Server
2017/01/11 17:26:02 [NAT] Failed to discover upnp: write udp4 0.0.0.0:56651->239.255.255.250:1900: i/o timeout
2017/01/11 17:26:02 [NAT] Failed to discover router using natpmp and upnp.
2017/01/11 17:38:58 [NAT] Failed to discover upnp: write udp4 0.0.0.0:55024->239.255.255.250:1900: i/o timeout
2017/01/11 17:38:58 [NAT] Failed to discover router using natpmp and upnp.
Interesting, my router is at 192.168.0.1 which I also had trouble with.
Mine is 192.168.1.254
What kind of router?
Pace PLC 5268AC
https://www.arris.com/globalassets/resources/data-sheets/5268ac.pdf
I know my port forwarding works, because I configured it for Plex and works fine.
Looks like the router might not support automatic port forwarding, so just setup a manual rule like you did for Plex. The port is 8089.
My router does not support uPNP so I did setup a manual rule for port 8089. Does not work.
Sorry the UI appears to be more confusing than we intended. If you have forwarded the port manually then you can uncheck the box. All it does is try to port forward for you.
Thank you for the clarification.
