Remote Browser Login Problems
The last couple of days I have been having problems getting into the channels dvr remotely through a browser. The phone app will work but not the browser. I keep getting:
{"error":"unauthorized access from XX.XXX.X.XXX"}
at the top of the page. I have used different locations, I have rebooted the router, I redid the port forward, I rebooted the computer (Windows 10) and I made sure I updated to the latest Beta(2020.02.02.0138). How can I correct this? In house it is fine. Just remote login.
Which browser? Are you using my.channelsdvr.net ?
I’ve had the same using safari on iOS.
Yes my.channelsdvr.net and it happens with Safari, Chrome and Edge Chromium. I just checked Firefox and it worked fine. Brave works fine. Strange thing now too. Using Edge Chromium I can log in with one profile but the other will fail.
Checked again this morning and the issue continues...
Same happens for me in Chrome and Edge
New build is uploading with a fix.
Thank you. It appears to be fixed!
Confirmed. Looks good now.
