Remote Creation of Series Pass
From another thread, @racameron said:
"So what you are saying is: What is the API endpoint for creating a pass, and what is the required JSON payload?
If you could, start a new thread, with your question clearly stated. That way, other users who have similar questions can easily find the discussion."
I will try to make this as clear as I can.
From a machine that is NOT the server, I want to send a JSON payload that will create a new series pass for a specified program that is already in the guide, but does not already exist as a series pass on the server.
What goes into the JSON package and what HTTP address do I send it to with CURL?
Ken
PUT /dvr/rules/new
{"SeriesID":"123456"}
In use, you might try:
DVR_IP=… curl -XPUT --data-binary '{"SeriesID":"123456"}' "http://${DVR_IP}:8089/dvr/rules/new"
Of course, you'll want to put your own server's IP address in there, as well as the actual SeriesID of the program you're setting a pass for.
Here's what I sent:
curl -XPUT --data-binary '{"SeriesID":"10409716"}' "http:/192.168.0.232:8089/dvr/rules/new"
It appears to have done nothing.
Ken
Try This
curl "http:/192.168.0.232:8089/dvr/rules/new" --data-binary '{"EQ":{"SeriesID":"10409716"},"Name":"NEW Test Pass#1"}'
And if you're running curl from Windows command line you need to quote the json payload with double quotes and escape inner quotes.
curl "http:/192.168.0.232:8089/dvr/rules/new" --data-binary "{\"EQ\":{\"SeriesID\":\"10409716\"},\"Name\":\"NEW Test Pass#1\"}"
Yes, that works. It will take more programming effort than I anticipated to retrieve the Series ID number from my Schedules Direct data, but it looks possible. If you have any ideas on this I would appreciate it.
One more thing, is there a tag to indicate Scan/No-Scan for commercials? Is any of this stuff documented anywhere?
Thanks for all your help.
Ken
Not I.
Detect Commercials is a Show Setting. Once you have recorded something you can access it from the Recordings>Shows>ShowName gear dropdown
No documentation other than scattered over the forum in posts. You can discover some endpoints like this by examining the network inspector in your browser.
