I set everything up to use channels on iOS when away from home with port forwarding and it worked fine yesterday when I was on cellular away from home. Today, I got on away from home and saw this message. The computer is still on, everything is still powered up, I have internet access at home, but something changed. I went in to my settings and logged out from remote dvr and then tried to log back in. It gave me an error message that it failed to access DVR. I went to configure on my computer and turned off remote DVR and turned it back on, and then tried this while phone was disconnected from wifi, and I got the same message. What's going on? Nothing on the computer has changed, it hasn't even been in sleep mode.Uploading...
Same issue here!
Same
Same here. Looks like there was a configuration change on the Lets Encrypt servers that’s causing problems for a lot of people: https://community.letsencrypt.org/t/net-err-cert-authority-invalid-error-on-my-website/55334/27?u=tmm1
I’m hoping they can fix it today now that they figured out what changed. If not, I’ll put in a work-around on our side.
This should be working again.
Thanks. I just started using the DMZ we talked in a different post and I thought I had done something wrong. Cheers!
It’s messing up again for me
Ran some more tests today. On my LTE I had no issues. But on the local boba shop’s Wi-Fi, I was seeing a certificate error still.
There’s a new iOS update on the store today which adds a reconnect option in case the remote DVR gets disconnected.
Hi there… I’m having a similar issue
The remote DVR was working great using the “automatic setting” but now it’s not.
2018/03/15 17:48:36 [NAT] Failed to discover upnp: write udp4 0.0.0.0:50446->239.255.255.250:1900: i/o timeout
2018/03/15 17:48:36 [NAT] Failed to discover router using natpmp and upnp.
2018/03/15 17:49:04 [NAT] Failed to discover upnp: write udp4 0.0.0.0:58282->239.255.255.250:1900: i/o timeout
2018/03/15 17:49:04 [NAT] Failed to discover router using natpmp and upnp.
2018/03/15 17:56:08 [NAT] Failed to discover upnp: write udp4 0.0.0.0:59645->239.255.255.250:1900: i/o timeout
2018/03/15 17:56:08 [NAT] Failed to discover router using natpmp and upnp.
2018/03/15 17:56:12 [NAT] Failed to discover upnp: write udp4 0.0.0.0:59646->239.255.255.250:1900: i/o timeout
2018/03/15 17:56:12 [NAT] Failed to discover router using natpmp and upnp.
I’d recommend just turning off automatic mode and setting up the port forwarding manually.
