My Remote DVR section of the server ui does not have the enable button, what am I missing?
Thanks
It was changed to Port Forwarding: On
OK, Thanks I will try to get it to connect - I can test from the house using the my.channelsdvr.net URL - correct?
Turned off my wifi and worked like a charm.
Thanks again tmm1!
You guys are awesome
