Remote HDHomerun Flex 4K
Before I begin the investigation, just wanted some input on if it would be possible to get Channels DVR to see a HDHomerun Flex 4K in another location. I'm in PA and would like to access a unit in NY.
My thought was that this might be possible using Channels DVR in conjunction with Tailscale. Both locations have symmetrical FIOS Gigabit internet service.
Looking for input on if I should stop the investigation before it begins.
Thanks
Spin up a second server in the NY location and enable Tailscale option on both and create a custom channel on the PA server to import the m3u playlist
Thank you Rice, much appreciated.
I'll give it a go.
After settling up Tailscale and noting the NY ip address use it to set up the custom channel. Choose stream format hls and source as url with
http://100.xxx.xxx.xx:8089/devices/ANY/channels.m3u?codec=copy
For XMLTV guide data use
http://100.xxx.xxx.xx:8089/devices/ANY/guide/xmltv?duration=604800
