I wonder if it was just a bad connection, or if my server is underpowered? This morning it is working better - i am not sure what I did - I think i increased the resolution thinking that its closer to the original format and the transcoder wouldn't have to work so hard.
2019/07/02 07:41:02 [HLS] Starting transcoder for file2062-be0665eedb4d at 0s from 50.239.174.98 (encoder=libx264, resolution=1080, deinterlacer=blend, bitrate=10000)
[mpegts @ 0x2356300] Dropped corrupted packet (stream = 1)
[mpegts @ 0x2356300] Dropped corrupted packet (stream = 2)
[libx264 @ 0x237dac0] MB rate (118800000) > level limit (522240)
[mpegts @ 0x2356300] Dropped corrupted packet (stream = 0)
Last message repeated 2 times
[mpeg2video @ 0x235e9c0] ac-tex damaged at 26 29
[mpeg2video @ 0x235e9c0] Warning MVs not available
Last message repeated 1 times
Last message repeated 9 times
Error while decoding stream #0:2: Error number -16976906 occurred
[mpeg2video @ 0x235e9c0] skip with previntra
[mpeg2video @ 0x235e9c0] mb incr damaged
Error while decoding stream #0:1: Error number -16976906 occurred
2019/07/02 07:48:21 [HLS] Stopping transcoder session file2062-be0665eedb4d @ 7m16.938667s
