One username and one password, definitely a security issue. Multiple users, with restricted access to settings would be great.
Channels is built to be a personal experience. It’s not our intention for it to be used by other people outside of your family and home.
Not sure you really understand the issue. Don’t want any “accidental” changes to the server.
You can use the server side settings to put the other clients into kiosk mode. This removes the settings screen from their apps.
Check out the Clients section on the Channels DVR Server web admin.
Would this work for remote access?
This remove the settings section of any Channels app connected to your server. Local or remote.
So make it global?
Global or per device. It's up to you.
