Remote Viewing causing buffering and error of dropped corrupted packet
While viewing channels DVR remotely via firestick the stream buffers and creating errors in error log.
Dropped corrupted packet
[ENC] segment has unexpected duration
Version 2019.12.05.0128
Can you help identify what is causing this issue.
Are you watching Live TV or Recordings?
Errors are occurring on recorded tv but remote buffering is occurring on both
Do you have the Adaptive Streaming option in the Transcoder settings enabled? With it enabled, I wouldn't expect buffering for recorded TV.
Yes I do
Very odd. If you could submit a diagnostic log to us after experiencing the buffering while watching a recording that would be very helpful in tracking down what's going on.
Here is a log file showing errors.
2019/12/31 10:27:11 [HLS] Starting transcoder for channel 1012 from 68.5.69.60 (encoder=libx264, resolution=1080, deinterlacer=blend, bitrate=8000)
[mpeg2video @ 0x80141c300] ac-tex damaged at 26 30
[mpeg2video @ 0x80141c300] ac-tex damaged at 23 21
[mpeg2video @ 0x80141c300] ac-tex damaged at 24 0
[mpeg2video @ 0x80141c300] ac-tex damaged at 20 16
[mpeg2video @ 0x80141c300] ac-tex damaged at 17 41
[mpeg2video @ 0x80141c300] ac-tex damaged at 73 32
[mpeg2video @ 0x80141c300] ac-tex damaged at 31 23
[mpeg2video @ 0x80141c300] ac-tex damaged at 16 33
[mpeg2video @ 0x80141c300] ac-tex damaged at 21 26
[mpeg2video @ 0x80141c300] Warning MVs not available
[mpeg2video @ 0x80141c300] ac-tex damaged at 64 29
[mpeg2video @ 0x80141c300] ac-tex damaged at 28 37
[mpeg2video @ 0x80141c300] ac-tex damaged at 23 22
[mpeg2video @ 0x80141c300] ac-tex damaged at 70 31
[mpeg2video @ 0x80141c300] ac-tex damaged at 56 4
[mpeg2video @ 0x80141c300] ac-tex damaged at 45 23
[mpeg2video @ 0x80141c300] ac-tex damaged at 13 40
[mpeg2video @ 0x80141c300] ac-tex damaged at 59 6
[mpeg2video @ 0x80141c300] ac-tex damaged at 66 42
[mpeg2video @ 0x80141c300] ac-tex damaged at 51 32
[mpeg2video @ 0x80141c300] ac-tex damaged at 55 26
[mpeg2video @ 0x80141c300] ac-tex damaged at 36 8
[mpeg2video @ 0x80141c300] ac-tex damaged at 29 33
[mpeg2video @ 0x80141c300] ac-tex damaged at 2 44
[mpeg2video @ 0x80141c300] ac-tex damaged at 47 34
[mpeg2video @ 0x80141c300] ac-tex damaged at 17 35
pipe:: corrupt decoded frame in stream 0
[mpeg2video @ 0x80141c300] ac-tex damaged at 49 2
[mpeg2video @ 0x80141c300] ac-tex damaged at 33 21
[mpeg2video @ 0x80141c300] ac-tex damaged at 63 5
[mpeg2video @ 0x80141c300] ac-tex damaged at 24 8
[mpeg2video @ 0x80141c300] ac-tex damaged at 16 25
[mpeg2video @ 0x80141c300] ac-tex damaged at 26 25
[mpeg2video @ 0x80141c300] ac-tex damaged at 37 36
[mpeg2video @ 0x80141c300] ac-tex damaged at 9 37
[mpeg2video @ 0x80141c300] ac-tex damaged at 32 38
[mpeg2video @ 0x80141c300] ac-tex damaged at 31 39
[mpeg2video @ 0x80141c300] ac-tex damaged at 31 12
[mpeg2video @ 0x80141c300] ac-tex damaged at 28 28
[mpeg2video @ 0x80141c300] ac-tex damaged at 13 42
[mpeg2video @ 0x80141c300] ac-tex damaged at 19 43
[mpeg2video @ 0x80141c300] ac-tex damaged at 34 29
[mpeg2video @ 0x80141c300] ac-tex damaged at 28 15
[mpeg2video @ 0x80141c300] ac-tex damaged at 14 31
[mpeg2video @ 0x80141c300] ac-tex damaged at 10 32
[mpeg2video @ 0x80141c300] ac-tex damaged at 22 33
[mpeg2video @ 0x80141c300] ac-tex damaged at 59 17
[mpeg2video @ 0x80141c300] ac-tex damaged at 22 34
[mpeg2video @ 0x80141c300] qscale == 0
[mpeg2video @ 0x80141c300] ac-tex damaged at 53 35
[mpeg2video @ 0x80141c300] ac-tex damaged at 15 0
[mpeg2video @ 0x80141c300] ac-tex damaged at 16 28
[mpeg2video @ 0x80141c300] ac-tex damaged at 33 36
[mpeg2video @ 0x80141c300] ac-tex damaged at 48 28
[mpeg2video @ 0x80141c300] ac-tex damaged at 14 22
[mpeg2video @ 0x80141c300] ac-tex damaged at 31 31
[mpeg2video @ 0x80141c300] ac-tex damaged at 51 24
[mpeg2video @ 0x80141c300] ac-tex damaged at 37 33
[mpeg2video @ 0x80141c300] ac-tex damaged at 48 37
[mpeg2video @ 0x80141c300] ac-tex damaged at 54 35
[mpeg2video @ 0x80141c300] ac-tex damaged at 18 26
[mpeg2video @ 0x80141c300] ac-tex damaged at 9 39
[mpeg2video @ 0x80141c300] ac-tex damaged at 41 39
[mpeg2video @ 0x80141c300] ac-tex damaged at 14 43
[mpeg2video @ 0x80141c300] end mismatch left=149 147142 at 0 45
Last message repeated 1 times
[mpeg2video @ 0x80141c300] ac-tex damaged at 26 18
[mpeg2video @ 0x80141c300] ac-tex damaged at 32 5
[mpeg2video @ 0x80141c300] ac-tex damaged at 22 6
[mpeg2video @ 0x80141c300] ac-tex damaged at 15 19
[mpeg2video @ 0x80141c300] ac-tex damaged at 22 8
[mpeg2video @ 0x80141c300] ac-tex damaged at 27 23
[mpeg2video @ 0x80141c300] ac-tex damaged at 18 4
[mpeg2video @ 0x80141c300] ac-tex damaged at 29 10
[mpeg2video @ 0x80141c300] ac-tex damaged at 6 24
[mpeg2video @ 0x80141c300] ac-tex damaged at 21 34
[mpeg2video @ 0x80141c300] ac-tex damaged at 65 38
[mpeg2video @ 0x80141c300] ac-tex damaged at 10 12
[mpeg2video @ 0x80141c300] ac-tex damaged at 7 5
[mpeg2video @ 0x80141c300] ac-tex damaged at 15 14
[mpeg2video @ 0x80141c300] ac-tex damaged at 34 25
[mpeg2video @ 0x80141c300] ac-tex damaged at 26 39
[mpeg2video @ 0x80141c300] ac-tex damaged at 19 15
[mpeg2video @ 0x80141c300] ac-tex damaged at 33 11
[mpeg2video @ 0x80141c300] ac-tex damaged at 60 2
[mpeg2video @ 0x80141c300] ac-tex damaged at 5 21
[mpeg2video @ 0x80141c300] ac-tex damaged at 67 38
[mpeg2video @ 0x80141c300] ac-tex damaged at 2 3
[mpeg2video @ 0x80141c300] ac-tex damaged at 58 12
[mpeg2video @ 0x80141c300] ac-tex damaged at 3 22
[mpeg2video @ 0x80141c300] ac-tex damaged at 10 8
[mpeg2video @ 0x80141c300] end mismatch left=215 47294A at 0 45
[mpeg2video @ 0x80141c300] ac-tex damaged at 2 26
[mpeg2video @ 0x80141c300] ac-tex damaged at 17 10
[mpeg2video @ 0x80141c300] ac-tex damaged at 65 8
[mpeg2video @ 0x80141c300] ac-tex damaged at 14 15
[mpeg2video @ 0x80141c300] ac-tex damaged at 64 25
[mpeg2video @ 0x80141c300] Invalid mb type in P-frame at 17 35
[mpeg2video @ 0x80141c300] ac-tex damaged at 20 19
[mpeg2video @ 0x80141c300] ac-tex damaged at 57 29
[mpeg2video @ 0x80141c300] end mismatch left=684 4D2C45 at 0 45
[mpeg2video @ 0x80141c300] ac-tex damaged at 9 17
[mpeg2video @ 0x80141c300] ac-tex damaged at 64 37
[mpeg2video @ 0x80141c300] ac-tex damaged at 57 30
[mpeg2video @ 0x80141c300] ac-tex damaged at 8 8
[mpeg2video @ 0x80141c300] ac-tex damaged at 22 42
[mpeg2video @ 0x80141c300] ac-tex damaged at 21 44
[mpeg2video @ 0x80141c300] ac-tex damaged at 31 40
[mpeg2video @ 0x80141c300] ac-tex damaged at 16 0
[mpeg2video @ 0x80141c300] ac-tex damaged at 37 10
[mpeg2video @ 0x80141c300] ac-tex damaged at 67 41
[mpeg2video @ 0x80141c300] ac-tex damaged at 4 14
[mpeg2video @ 0x80141c300] ac-tex damaged at 72 38
[mpeg2video @ 0x80141c300] ac-tex damaged at 15 5
[mpeg2video @ 0x80141c300] ac-tex damaged at 35 26
[mpeg2video @ 0x80141c300] ac-tex damaged at 23 17
[mpeg2video @ 0x80141c300] ac-tex damaged at 66 17
[mpeg2video @ 0x80141c300] skip with previntra
[mpeg2video @ 0x80141c300] ac-tex damaged at 9 30
[mpeg2video @ 0x80141c300] ac-tex damaged at 1 35
[mpeg2video @ 0x80141c300] ac-tex damaged at 50 24
[mpeg2video @ 0x80141c300] ac-tex damaged at 9 41
[mpeg2video @ 0x80141c300] ac-tex damaged at 6 12
[mpeg2video @ 0x80141c300] ac-tex damaged at 17 27
[mpeg2video @ 0x80141c300] ac-tex damaged at 57 15
[mpeg2video @ 0x80141c300] ac-tex damaged at 68 17
[mpeg2video @ 0x80141c300] ac-tex damaged at 40 9
Last message repeated 3 times
[mpeg2video @ 0x80141c300] ac-tex damaged at 60 41
[mpeg2video @ 0x80141c300] ac-tex damaged at 30 26
[mpeg2video @ 0x80141c300] ac-tex damaged at 25 18
[mpeg2video @ 0x80141c300] ac-tex damaged at 64 36
[mpeg2video @ 0x80141c300] ac-tex damaged at 9 42
[mpeg2video @ 0x80141c300] ac-tex damaged at 9 10
[mpeg2video @ 0x80141c300] ac-tex damaged at 58 39
[mpeg2video @ 0x80141c300] ac-tex damaged at 31 27
[mpeg2video @ 0x80141c300] ac-tex damaged at 59 31
[mpeg2video @ 0x80141c300] ac-tex damaged at 43 25
[mpeg2video @ 0x80141c300] ac-tex damaged at 78 9
[mpeg2video @ 0x80141c300] ac-tex damaged at 38 11
[mpeg2video @ 0x80141c300] ac-tex damaged at 48 16
[mpeg2video @ 0x80141c300] ac-tex damaged at 74 20
[mpeg2video @ 0x80141c300] ac-tex damaged at 16 24
[mpeg2video @ 0x80141c300] ac-tex damaged at 19 31
[mpeg2video @ 0x80141c300] ac-tex damaged at 24 16
[mpeg2video @ 0x80141c300] ac-tex damaged at 12 39
[mpeg2video @ 0x80141c300] ac-tex damaged at 49 0
[mpeg2video @ 0x80141c300] ac-tex damaged at 5 1
[mpeg2video @ 0x80141c300] ac-tex damaged at 77 29
[mpeg2video @ 0x80141c300] ac-tex damaged at 79 20
[mpeg2video @ 0x80141c300] ac-tex damaged at 20 14
Last message repeated 2 times
[mpeg2video @ 0x80141c300] ac-tex damaged at 24 4
overread 1
[mpeg2video @ 0x80141c300] ac-tex damaged at 64 23
[mpeg2video @ 0x80141c300] ac-tex damaged at 74 34
[mpeg2video @ 0x80141c300] ac-tex damaged at 75 25
[mpeg2video @ 0x80141c300] ac-tex damaged at 37 2
[mpeg2video @ 0x80141c300] ac-tex damaged at 11 5
[mpeg2video @ 0x80141c300] ac-tex damaged at 19 6
[mpeg2video @ 0x80141c300] ac-tex damaged at 4 16
[mpeg2video @ 0x80141c300] ac-tex damaged at 13 28
[mpeg2video @ 0x80141c300] ac-tex damaged at 0 20
[mpeg2video @ 0x80141c300] ac-tex damaged at 38 29
[mpeg2video @ 0x80141c300] ac-tex damaged at 5 36
[mpeg2video @ 0x80141c300] ac-tex damaged at 13 7
[mpeg2video @ 0x80141c300] ac-tex damaged at 20 43
[mpeg2video @ 0x80141c300] ac-tex damaged at 11 44
2019/12/31 11:19:00 [NAT] Successfully mapped port 8089 using natpmp
[mpeg2video @ 0x80141c300] end mismatch left=187 47294A at 0 45
[mpeg2video @ 0x80141c300] ac-tex damaged at 78 19
[mpeg2video @ 0x80141c300] ac-tex damaged at 28 10
[mpeg2video @ 0x80141c300] ac-tex damaged at 28 30
[mpeg2video @ 0x80141c300] ac-tex damaged at 68 25
[mpeg2video @ 0x80141c300] ac-tex damaged at 39 41
[mpeg2video @ 0x80141c300] ac-tex damaged at 38 23
[mpeg2video @ 0x80141c300] ac-tex damaged at 76 3
[mpeg2video @ 0x80141c300] ac-tex damaged at 6 32
[mpeg2video @ 0x80141c300] ac-tex damaged at 65 42
[mpeg2video @ 0x80141c300] ac-tex damaged at 30 3
[mpeg2video @ 0x80141c300] ac-tex damaged at 10 33
[mpeg2video @ 0x80141c300] ac-tex damaged at 54 8
[mpeg2video @ 0x80141c300] ac-tex damaged at 9 40
[mpeg2video @ 0x80141c300] ac-tex damaged at 46 40
[mpeg2video @ 0x80141c300] ac-tex damaged at 18 42
[mpeg2video @ 0x80141c300] ac-tex damaged at 25 21
[mpeg2video @ 0x80141c300] ac-tex damaged at 49 13
[mpeg2video @ 0x80141c300] ac-tex damaged at 51 25
[mpeg2video @ 0x80141c300] ac-tex damaged at 69 40
[mpeg2video @ 0x80141c300] ac-tex damaged at 29 17
[mpeg2video @ 0x80141c300] ac-tex damaged at 30 18
[mpeg2video @ 0x80141c300] ac-tex damaged at 32 20
[mpeg2video @ 0x80141c300] ac-tex damaged at 62 7
[mpeg2video @ 0x80141c300] ac-tex damaged at 17 40
[mpeg2video @ 0x80141c300] ac-tex damaged at 45 41
[mpeg2video @ 0x80141c300] end mismatch left=368 A4B13 at 0 45
[mpeg2video @ 0x80141c300] ac-tex damaged at 31 9
[mpeg2video @ 0x80141c300] ac-tex damaged at 43 10
[mpeg2video @ 0x80141c300] ac-tex damaged at 40 34
[mpeg2video @ 0x80141c300] ac-tex damaged at 68 3
[mpeg2video @ 0x80141c300] ac-tex damaged at 10 24
[mpeg2video @ 0x80141c300] ac-tex damaged at 6 35
[mpeg2video @ 0x80141c300] ac-tex damaged at 27 18
overread 5
[mpeg2video @ 0x80141c300] ac-tex damaged at 24 9
[mpeg2video @ 0x80141c300] ac-tex damaged at 38 27
[mpeg2video @ 0x80141c300] ac-tex damaged at 63 3
[mpeg2video @ 0x80141c300] ac-tex damaged at 11 28
[mpeg2video @ 0x80141c300] ac-tex damaged at 2 38
[mpeg2video @ 0x80141c300] ac-tex damaged at 50 15
[mpeg2video @ 0x80141c300] ac-tex damaged at 22 40
[mpeg2video @ 0x80141c300] ac-tex damaged at 6 41
[mpeg2video @ 0x80141c300] ac-tex damaged at 65 16
[mpeg2video @ 0x80141c300] ac-tex damaged at 51 31
[mpeg2video @ 0x80141c300] ac-tex damaged at 13 32
[mpeg2video @ 0x80141c300] ac-tex damaged at 44 9
[mpeg2video @ 0x80141c300] ac-tex damaged at 57 5
[mpeg2video @ 0x80141c300] ac-tex damaged at 10 30
[mpeg2video @ 0x80141c300] ac-tex damaged at 55 33
[mpeg2video @ 0x80141c300] ac-tex damaged at 22 2
[mpeg2video @ 0x80141c300] ac-tex damaged at 63 15
[mpeg2video @ 0x80141c300] ac-tex damaged at 44 3
[mpeg2video @ 0x80141c300] end mismatch left=780 46230A at 0 45
[mpeg2video @ 0x80141c300] ac-tex damaged at 38 9
[mpeg2video @ 0x80141c300] ac-tex damaged at 39 27
[mpeg2video @ 0x80141c300] ac-tex damaged at 5 9
[mpeg2video @ 0x80141c300] ac-tex damaged at 53 39
[mpeg2video @ 0x80141c300] ac-tex damaged at 45 19
[mpeg2video @ 0x80141c300] ac-tex damaged at 33 40
[mpeg2video @ 0x80141c300] ac-tex damaged at 18 19
[mpeg2video @ 0x80141c300] ac-tex damaged at 6 7
[mpeg2video @ 0x80141c300] ac-tex damaged at 53 44
That means you're getting a bad signal from your hdhomerun. What does it show on Tuner Status page on my.hdhomerun.com for Signal Quality and Strength.
Are the HDHR and the DVR computer plugged into the same physical switch?
I have 4 HDHR’s and below are the signal strength.
HDHomeRun 1 signal strength = 93% (-4.6 dBmV)
HDHomeRun 1 signal quality = 100% (38.3 dB)
HDHomeRun 2 signal strength = 93% (-4.4 dBmV)
HDHomeRun 2 signal quality = 100% (38.5 dB)
HDHomeRun 3 signal strength = 93% (-4.4 dBmV)
HDHomeRun 3 signal quality = 100% (38.5 dB)
HDHomeRun 4 signal strength = 93% (-4.3 dBmV)
HDHomeRun 4 signal quality = 100% (38.1 dB)
I just moved all of HDHR's and DVR computer to the same switch.
I'll report back shortly and let you know if that was successful
Thanks for all the help. The suggestion of putting everything on one switch was the solution.
