Remote viewing problem
Trying to watch the football game tonight remotely but all kinds of apparent streaming problems, this repeating over and over:
] : file19505-900786f98a26:  [h264_qsv @ 0000018b79e7e180] Error during encoding: device failed (-17)
2024/12/05 20:27:52.945245 [HLS] ffmpeg: file19505-900786f98a26:  Video encoding failed: I/O error
2024/12/05 20:27:52.969999 [HLS] ffmpeg: file19505-900786f98a26:  [aac @ 0000018b79e796c0] 2 frames left in the queue on closing
2024/12/05 20:27:52.969999 [HLS] ffmpeg: file19505-900786f98a26:  [aac @ 0000018b79dc4f80] 2 frames left in the queue on closing
2024/12/05 20:27:53.030079 [ENC] Encoder stopped for NFL Football Green Bay Packers at Detr 2024-12-05-1845.mpg in D:\CHANNELS\ChannelsDVR\Streaming\file19505-900786f98a26-3620969839\encoder-4982-3588450487 after starting from 4982 without encoding any segments. Marked segment as failed.
2024/12/05 20:27:53.033193 [ENC] Starting encoder for NFL Football Green Bay Packers at Detr 2024-12-05-1845.mpg in D:\CHANNELS\ChannelsDVR\Streaming\file19505-900786f98a26-3620969839\encoder-4983-1638397224 at 4983 (5668.629203) (encoder=h264_qsv, codec=h264, acodec=aac, resolution=720, deinterlacer=blend, bitrate=3916, segment_size=0.01)
2024/12/05 20:27:54.906227 [HLS] ffmpeg: file19505-900786f98a26:  [h264_qsv @ 00000288d175f740] Error during encoding: device failed (-17)
2024/12/05 20:27:54.906227 [HLS] ffmpeg: file19505-900786f98a26:  Video encoding failed: I/O error
2024/12/05 20:27:54.920619 [HLS] ffmpeg: file19505-900786f98a26:  [aac @ 00000288cfdeaac0] 2 frames left in the queue on closing
2024/12/05 20:27:54.920619 [HLS] ffmpeg: file19505-900786f98a26:  [aac @ 00000288cfdeaec0] 2 frames left in the queue on closing
2024/12/05 20:27:55.027579 [ENC] Encoder stopped for NFL Football Green Bay Packers at Detr 2024-12-05-1845.mpg in D:\CHANNELS\ChannelsDVR\Streaming\file19505-900786f98a26-3620969839\encoder-4983-1638397224 after starting from 4983 without encoding any segments
2024/12/05 20:27:55.029731 [ENC] Starting encoder for NFL Football Green Bay Packers at Detr 2024-12-05-1845.mpg in D:\CHANNELS\ChannelsDVR\Streaming\file19505-900786f98a26-3620969839\encoder-4984-679376878 at 4984 (5669.630203) (encoder=h264_qsv, codec=h264, acodec=aac, resolution=720, deinterlacer=blend, bitrate=3916, segment_size=0.01)
2024/12/05 20:27:56.950705 [HLS] ffmpeg: file19505-900786f98a26:  [h264_qsv @ 0000018d4506cf40] Error during encoding: device failed (-17)
2024/12/05 20:27:56.950705 [HLS] ffmpeg: file19505-900786f98a26:  Video encoding failed: I/O error
2024/12/05 20:27:56.964722 [HLS] ffmpeg: file19505-900786f98a26:  [aac @ 0000018d4506e140] 2 frames left in the queue on closing
2024/12/05 20:27:56.965248 [HLS] ffmpeg: file19505-900786f98a26:  [aac @ 0000018d4698aac0] 2 frames left in the queue on closing
2024/12/05 20:27:57.028993 [ENC] Encoder stopped for NFL Football Green Bay Packers at Detr 2024-12-05-1845.mpg in D:\CHANNELS\ChannelsDVR\Streaming\file19505-900786f98a26-3620969839\encoder-4984-679376878 after starting from 4984 without encoding any segments
2024/12/05 20:27:57.031166 [ENC] Starting encoder for NFL Football Green Bay Packers at Detr 2024-12-05-1845.mpg in D:\CHANNELS\ChannelsDVR\Streaming\file19505-900786f98a26-3620969839\encoder-4984-3580031963 at 4984 (5669.630203) (encoder=h264_qsv, codec=h264, acodec=aac, resolution=720, deinterlacer=blend, bitrate=3916, segment_size=0.01)
2024/12/05 20:27:57.087940 [HLS] ffmpeg: file19505-900786f98a26:  [mpegts @ 0000024bc1b7ff80] stream 1 : no PTS found at end of file, duration not set
2024/12/05 20:27:58.874967 [HLS] ffmpeg: file19505-900786f98a26:  [h264_qsv @ 0000024bc1be17c0] Error during encoding: device failed (-17)
2024/12/05 20:27:58.874967 [HLS] ffmpeg: file19505-900786f98a26:  Video encoding failed: I/O error
2024/12/05 20:27:58.890269 [HLS] ffmpeg: file19505-900786f98a26:  [aac @ 0000024bc3680700] 2 frames left in the queue on closing
2024/12/05 20:27:58.890269 [HLS] ffmpeg: file19505-900786f98a26:  [aac @ 0000024bc3680f00] 2 frames left in the queue on closing
2024/12/05 20:27:59.028440 [ENC] Encoder stopped for NFL Football Green Bay Packers at Detr 2024-12-05-1845.mpg in D:\CHANNELS\ChannelsDVR\Streaming\file19505-900786f98a26-3620969839\encoder-4984-3580031963 after encoding 4984 to 4988
Anyone have any idea why this is happening and how to fix it?!?!
Logs submitted.
You can try rebooting, or disable the hardware acceleration
What happens to all the active recordings going (including the football game) when I reboot the computer? Do they just pick up again where they left off leaving a 3 minute gap (or so) in the recording?
Yes it resumes with a gap
