Remote Web Access?
I’ve got everything setup and working for iOS and tvOS, had to configure port forwarding manually. Is is there a way to access the web player remotely as well? I assume it gives instructions if it is able to auto-enable access but I only get the error message.
If you have configured the port forwarding manually, then leave the remote access box unchecked.
You can find your public ip on a site like ipchicken.com and connect to x.x.x.x:8089 remotely to access the DVR web UI.
Thanks. One other thing, the “on now” web UI is missing a selection option, the only thing it shows for me is favorites with now way of choosing HD, Movies, Sports,ect.
