Hi there, I'm loving the interface of Channels, this is what TV on an Apple TV should be like!
I'm using the app and the DVR in an unsupported country (Netherlands, Ziggo cable) and have chosen a German postcode near the border in the hope I'd get at least some guide entries - and yes, I have 8 or 9 that match. Others are listed as Unknown, which is fine for me right now (I do hope for support at some point, Ziggo offers most of their channels in SD as ClearQAM).
Point is, I want to remove the listings and guide data for the channels that DVR thinks it has matched correctly (but really hasn't) and set them to Unknown as well. However, the 'Edit' interface doesn't seem to let me do that. I can change what channel is matched but cannot remove it. The X that is visible on some channels is not visible on others. Can this be done?
Cheers
Friso
Where does this data come from actually? Is this something Silicon Dust provides?
