I have my Channels DVR storage on an internal Windows hard drive. The DVR recordings folder is not on the same drive as the Channels Server program. I am quickly running out of space and plan on installing a new internal hard drive and would like to move all of my existing recordings/content there (and have new content saved there as well). What is the best/easiest way to do this? Would it be as simple as the following?
- Install new hard drive and format it appropriately.
- Save a new Channels DVR database backup (by clicking the save database backup).
- Copy the entire Channels DVR folder from the old drive to the new drive.
- Un-check the DVR box in the basic setup.
- Select the new drive DVR folder that I just copied over.
- Re-check the DVR box in the basic setup.
Would that move everything over and keep all my shows, season passes, watched status, etc.? Anything else I am missing?
, whereas HDD had glitches
