Replacing Plex with Channels?
I've had Plex forever, only use it for on demand local movies and shows. Since channels can do that by adding the folders to the local library, can anyone comment on settings/config to get the most of channels or maybe I should try something else, etc... I'm open to suggestions.
Channels can do what you want. There is no harm in trying it and see if you like it.
