Request for your current Sat>IP UK Freesat M3U & How you built & maintain it
Hi, Would one or more Channel DVR users here be kind enough to share their current and working Sat>IP UK Freesat M3U text please.
Also adding how you originally built and maintain it.
I have a working Kathrein EXIP 418 & HDHR Quattro Channels DVR with kind help from @neild7744 & @GeoffT but I've struggled, without trying to detail here what I've tried, to produce a full M3U file despite a lot of studying & limited attempts with TVheadend and DVBviewer as well hand crafting (inc. checking & modification of others files) using KingOfSat.
I'd very much appreciate your help as I'm keen to migrate away from Sky Q when my next contract term comes around but crucially achieving full WAF (Wife Approval Factor).
Many thanks in anticipation & Happy Easter for those of you celebrating it.
Regards,
Steve
Channels DVR Subscriber
You have to maintain it, and thats the issue - Its a pain.
Also blind scanning Astra 28.2 for all free to air (FTA) is better as channels tagged Freesat / on the Freesat platform are quite limited.
Even if you manage to generate channels lists (M3U) regularly, any additions / changes to your M3U will probably cause problems with your EPG mapping in Channels DVR - You will more than likely have to keep re-assigning it if your M3U list changes quite a lot due to channel changes / updates to Astra 28.2 FTA.
What particular channels are you looking for in Freesat from Sky? Seems like a total headache to get freesat working in Channels. I would just pipe those channels in and use a HDHR to get the rest via freeview
There is no getting away from it, Sat>IP is a pain to maintain.
When I had the EXIP418 I kept a spreadsheet with my m3U file structure in it. I set up my own data line for each channel I wanted and included the tvc-guide-stationid="XXXXXX" tag for each channel. It was a fair bit of work initially, but once the stationid tags are set you don't need to map your channels to the epg, it is all automatic. I got the stationid numbers from searching within the output from http://{ip of channels server}:8089/dvr/guide/stations/GBR-1000193-DEFAULT.
I also had the spreadsheet add a tvg-chno="NN" tag in each line so that I could choose my own channel numbers. It was very complicated but did work in the end and made updates as easy as they could be but I still had to keep an eye on the KingofSat etc websites for any changes to the SATIP data.
The channels seem to change/move a lot last year and I got so frustrated trying to work out the exact PIDs required for any channel alteration. Often different websites had different data for them and you just had find the right ones by trial and error. In the end I splashed out on a Digital Devices Octopus NET - SX8 SL because that has it's own inbuilt network scan facility. Once you do a scan it produces it's own M3U file which can go direct into Channels.
In my case, because I still want the custom channel numbers and I don't want to have to map the channels to the EPG each time, I still use the same spreadsheet I created for the EXIP418 for the EXTINF lines but now can just cut and paste the Satip data I need for each channel from the m3u file produced by the device, so it is a lot easier.
It is such a shame that so many channels are of poorer SD quality / missing HD versions / missing altogether on DVB-T compared DVB-S as it is an expensive and/or time consuming process to keep on top of it whichever way you go about it.
Latest ASTRA 28.2 FTA Scan (TV Only):
#EXTM3U
#EXTINF:-1,(sub b +1000)
#EXTVLCOPT:program=49000
rtsp://SATIPADDRESS/?src=1&freq=11934&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20
#EXTINF:-1,___4109
#EXTVLCOPT:program=47000
#EXTINF:-1,___4110
#EXTVLCOPT:program=48000
#EXTINF:-1,4seven
#EXTVLCOPT:program=8368
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,269,2357,2360,2356
#EXTINF:-1,5
#EXTVLCOPT:program=2101
rtsp://SATIPADDRESS/?src=1&freq=11305&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,268,2335,2338,2336
#EXTINF:-1,5 HD
#EXTVLCOPT:program=2108
rtsp://SATIPADDRESS/?src=1&freq=11305&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,267,2349,2350,2348
#EXTINF:-1,5 USA
#EXTVLCOPT:program=2102
rtsp://SATIPADDRESS/?src=1&freq=11305&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,272,2323,2326,2324
#EXTINF:-1,5+1
#EXTVLCOPT:program=2107
rtsp://SATIPADDRESS/?src=1&freq=11305&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,269,2341,2344,2342
#EXTINF:-1,50396
#EXTVLCOPT:program=50396
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,269,2325,2382,2326
#EXTINF:-1,5ACTION
#EXTVLCOPT:program=2109
rtsp://SATIPADDRESS/?src=1&freq=11305&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,271,2353,2357,2354
#EXTINF:-1,5SELECT
#EXTVLCOPT:program=2105
rtsp://SATIPADDRESS/?src=1&freq=11305&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,259,2317,2319,2318
#EXTINF:-1,5STAR
#EXTVLCOPT:program=2104
rtsp://SATIPADDRESS/?src=1&freq=11305&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,261,2305,2308,2306
#EXTINF:-1,5STAR+1
#EXTVLCOPT:program=2106
rtsp://SATIPADDRESS/?src=1&freq=11305&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,266,2311,2314,2312
#EXTINF:-1,5USA+1
#EXTVLCOPT:program=2103
rtsp://SATIPADDRESS/?src=1&freq=11305&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,273,2329,2331,2330
#EXTINF:-1,AAJ TAK
#EXTVLCOPT:program=54165
rtsp://SATIPADDRESS/?src=1&freq=11567&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,257,2314,2315
#EXTINF:-1,Aastha
#EXTVLCOPT:program=54229
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,269,2331,2332
#EXTINF:-1,Ahlebait TV
#EXTVLCOPT:program=7604
rtsp://SATIPADDRESS/?src=1&freq=11523&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,272,2319,2320
#EXTINF:-1,Akaal Channel
#EXTVLCOPT:program=52138
rtsp://SATIPADDRESS/?src=1&freq=11265&msys=dvbs&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,263,2318,2319
#EXTINF:-1,Al Jazeera HD
#EXTVLCOPT:program=55275
rtsp://SATIPADDRESS/?src=1&freq=11508&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,261,2311,2305,2313
#EXTINF:-1,Arirang TV HD
#EXTVLCOPT:program=53150
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,260,2309,2312
#EXTINF:-1,Arise News
#EXTVLCOPT:program=54210
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,267,2319,2322
#EXTINF:-1,ARY Digital
#EXTVLCOPT:program=55125
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,289,2357,2358
#EXTINF:-1,ATN
#EXTVLCOPT:program=55278
rtsp://SATIPADDRESS/?src=1&freq=11508&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,262,2310,2324
#EXTINF:-1,Babenation
#EXTVLCOPT:program=55240
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,263,2354,2355
#EXTINF:-1,BBC ALBA HD
#EXTVLCOPT:program=8926
rtsp://SATIPADDRESS/?src=1&freq=11023&msys=dvbs2&plts=off&fec=34&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,260,5500,5501
#EXTINF:-1,BBC Four HD
#EXTVLCOPT:program=10394
rtsp://SATIPADDRESS/?src=1&freq=10818&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20
#EXTVLCOPT:program=10365
#EXTINF:-1,BBC NEWS HD
#EXTVLCOPT:program=8921
rtsp://SATIPADDRESS/?src=1&freq=11023&msys=dvbs2&plts=off&fec=34&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,258,5000,5003,5001
#EXTINF:-1,BBC One CI HD
#EXTVLCOPT:program=10310
rtsp://SATIPADDRESS/?src=1&freq=10788&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,256,5300,5303,5301
#EXTINF:-1,BBC One EastHD
#EXTVLCOPT:program=10373
rtsp://SATIPADDRESS/?src=1&freq=10818&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,259,5500,5503,5501
#EXTINF:-1,BBC One EMidHD
#EXTVLCOPT:program=10374
rtsp://SATIPADDRESS/?src=1&freq=10818&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,261,5600,5603,5601
#EXTINF:-1,BBC One Lon HD
#EXTVLCOPT:program=10363
rtsp://SATIPADDRESS/?src=1&freq=10818&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,260,5000,5003,5001
#EXTINF:-1,BBC One NE HD
#EXTVLCOPT:program=6311
rtsp://SATIPADDRESS/?src=1&freq=10773&msys=dvbs2&plts=off&fec=34&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,257,5500,5503,5501
#EXTINF:-1,BBC One NI HD
#EXTVLCOPT:program=6943
rtsp://SATIPADDRESS/?src=1&freq=10847&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,256,5300,5302,5301
#EXTINF:-1,BBC One NW HD
#EXTVLCOPT:program=6331
rtsp://SATIPADDRESS/?src=1&freq=10773&msys=dvbs2&plts=off&fec=34&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,258,5100,5103,5101
#EXTINF:-1,BBC One ScotHD
#EXTVLCOPT:program=8901
rtsp://SATIPADDRESS/?src=1&freq=11023&msys=dvbs2&plts=off&fec=34&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,256,5100,5103,5101
#EXTINF:-1,BBC One SE HD
#EXTVLCOPT:program=6931
rtsp://SATIPADDRESS/?src=1&freq=10847&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,261,5400,5403,5401
#EXTINF:-1,BBC One Sth HD
#EXTVLCOPT:program=1204
rtsp://SATIPADDRESS/?src=1&freq=12168&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,260,515,577,644
#EXTINF:-1,BBC One SW HD
#EXTVLCOPT:program=10341
rtsp://SATIPADDRESS/?src=1&freq=10788&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,259,5200,5203,5201
#EXTINF:-1,BBC One Wal HD
#EXTVLCOPT:program=8911
rtsp://SATIPADDRESS/?src=1&freq=11023&msys=dvbs2&plts=off&fec=34&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,257,5200,5203,5201
#EXTINF:-1,BBC One WM HD
#EXTVLCOPT:program=8941
rtsp://SATIPADDRESS/?src=1&freq=11023&msys=dvbs2&plts=off&fec=34&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,259,5400,5403,5401
#EXTINF:-1,BBC One Wst HD
#EXTVLCOPT:program=10331
rtsp://SATIPADDRESS/?src=1&freq=10788&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,267,5100,5103,5101
#EXTINF:-1,BBC One Y&L HD
#EXTVLCOPT:program=6911
rtsp://SATIPADDRESS/?src=1&freq=10847&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,266,5800,5803,5801
#EXTINF:-1,BBC One Yks HD
#EXTVLCOPT:program=6371
rtsp://SATIPADDRESS/?src=1&freq=10773&msys=dvbs2&plts=off&fec=34&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,259,5200,5203,5201
#EXTINF:-1,BBC Parl HD
#EXTVLCOPT:program=6308
rtsp://SATIPADDRESS/?src=1&freq=10773&msys=dvbs2&plts=off&fec=34&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,256,5400,5403,5401
#EXTINF:-1,BBC RB 1 HD
#EXTVLCOPT:program=10329
rtsp://SATIPADDRESS/?src=1&freq=10788&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,263,5400,5402
#EXTINF:-1,BBC Three HD
#EXTVLCOPT:program=6971
#EXTVLCOPT:program=6951
#EXTINF:-1,BBC Two HD
#EXTVLCOPT:program=6940
rtsp://SATIPADDRESS/?src=1&freq=10847&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,258,5500,5503,5501
#EXTINF:-1,BBC Two NI HD
#EXTVLCOPT:program=6312
rtsp://SATIPADDRESS/?src=1&freq=10773&msys=dvbs2&plts=off&fec=34&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,264,5300,5303,5301
#EXTINF:-1,BBC Two Wal HD
#EXTVLCOPT:program=10364
rtsp://SATIPADDRESS/?src=1&freq=10818&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,263,5200,5203,5201
#EXTINF:-1,BBCScotlandHD
#EXTVLCOPT:program=10335
rtsp://SATIPADDRESS/?src=1&freq=10788&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,260,5000,5003,5001
#EXTINF:-1,Best Direct
#EXTVLCOPT:program=54112
rtsp://SATIPADDRESS/?src=1&freq=11567&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,256,2321,2322
#EXTINF:-1,BLAZE
#EXTVLCOPT:program=50350
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,263,2310,2314,2311
#EXTINF:-1,Bloomberg HD
#EXTVLCOPT:program=50261
rtsp://SATIPADDRESS/?src=1&freq=11670&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,263,2308,2314,2307
#EXTINF:-1,CBBC HD
#EXTVLCOPT:program=6952
rtsp://SATIPADDRESS/?src=1&freq=10847&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,264,5600,5603,5601
#EXTINF:-1,CBeebies HD
#EXTVLCOPT:program=10366
rtsp://SATIPADDRESS/?src=1&freq=10818&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,267,5300,5302,5301
#EXTINF:-1,Challenge
#EXTVLCOPT:program=6203
rtsp://SATIPADDRESS/?src=1&freq=12090&msys=dvbs2&plts=off&fec=89&pol=v&ro=0.35&sr=29500&mtype=qpsk&pids=0,16,17,20,283,530,593,671
#EXTVLCOPT:program=7202
rtsp://SATIPADDRESS/?src=1&freq=12148&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,277,516,582,644
#EXTINF:-1,Channel 4 HD
#EXTVLCOPT:program=8300
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,270,2364,2369,2366
#EXTVLCOPT:program=5249
rtsp://SATIPADDRESS/?src=1&freq=12168&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,259,512,576,640
rtsp://SATIPADDRESS/?src=1&freq=12168&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,263,518,579,647
#EXTVLCOPT:program=5246
rtsp://SATIPADDRESS/?src=1&freq=12226&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,262,518,578,645
#EXTVLCOPT:program=5248
rtsp://SATIPADDRESS/?src=1&freq=12363&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,256,514,578,649
#EXTVLCOPT:program=5202
rtsp://SATIPADDRESS/?src=1&freq=12363&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,263,518,582,652
#EXTINF:-1,Channel 4+1
#EXTVLCOPT:program=8315
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,256,2337,2339,2342
#EXTVLCOPT:program=8322
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,257,2343,2344,2348
#EXTVLCOPT:program=8364
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,262,2316,2319,2317
#EXTVLCOPT:program=8374
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,263,2322,2325,2323
#EXTINF:-1,Channels 24
#EXTVLCOPT:program=22310
rtsp://SATIPADDRESS/?src=1&freq=11493&msys=dvbs&plts=off&fec=56&pol=h&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,259,2305,2306
#EXTINF:-1,CHSTV
#EXTVLCOPT:program=55142
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,276,2326,2324
#EXTINF:-1,Clubland TV
#EXTVLCOPT:program=55113
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,256,2557,2558
#EXTINF:-1,CNBC HD
#EXTVLCOPT:program=5088
rtsp://SATIPADDRESS/?src=1&freq=12168&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,256,513,641
#EXTINF:-1,CNN HD
#EXTVLCOPT:program=50290
rtsp://SATIPADDRESS/?src=1&freq=11670&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,256,2324,2328,2325
#EXTINF:-1,Court TV
#EXTVLCOPT:program=54140
rtsp://SATIPADDRESS/?src=1&freq=11567&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,269,2305,2306
#EXTINF:-1,Cruise1st.tv
#EXTVLCOPT:program=54228
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,266,2305,2306
#EXTINF:-1,DAYSTAR HD
#EXTVLCOPT:program=55305
rtsp://SATIPADDRESS/?src=1&freq=11685&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,260,2309,2310
#EXTINF:-1,Deen TV
#EXTVLCOPT:program=55185
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,260,2314,2315
#EXTINF:-1,DMAX
#EXTVLCOPT:program=52440
rtsp://SATIPADDRESS/?src=1&freq=11038&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,265,2335,2327,2336
#EXTINF:-1,DMAX
#EXTVLCOPT:program=2916
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,260,2384,2383,2385
#EXTINF:-1,DMAX+1
#EXTVLCOPT:program=2905
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,256,2389,2394,2390
#EXTINF:-1,Dunamis TV
#EXTVLCOPT:program=52126
rtsp://SATIPADDRESS/?src=1&freq=11265&msys=dvbs&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,261,2305,2306
#EXTINF:-1,E4
#EXTVLCOPT:program=8380
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,271,2370,2373,2371
#EXTINF:-1,E4 Extra
#EXTVLCOPT:program=8367
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,268,2349,2354,2350
#EXTINF:-1,E4+1
#EXTVLCOPT:program=8305
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,264,2328,2332,2329
#EXTINF:-1,Eman Channel
#EXTVLCOPT:program=7105
rtsp://SATIPADDRESS/?src=1&freq=11641&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,262,2315,2316
#EXTINF:-1,ETV4
#EXTVLCOPT:program=6945
rtsp://SATIPADDRESS/?src=1&freq=10847&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,259,5500,5503,5501
#EXTINF:-1,ETV5
#EXTVLCOPT:program=10321
rtsp://SATIPADDRESS/?src=1&freq=10788&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,262,5100,5103,5101
#EXTINF:-1,Euronews
#EXTVLCOPT:program=54224
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,262,2310,2311
#EXTINF:-1,EWTN Catholic
#EXTVLCOPT:program=52136
rtsp://SATIPADDRESS/?src=1&freq=11265&msys=dvbs&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,258,2341,2342
#EXTINF:-1,Faith UK
#EXTVLCOPT:program=50384
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,272,2329,2328
#EXTINF:-1,Faith World TV
#EXTVLCOPT:program=54170
rtsp://SATIPADDRESS/?src=1&freq=11567&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,273,2328,2329
#EXTINF:-1,Film4
#EXTVLCOPT:program=8382
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,272,2375,2378,2376
#EXTINF:-1,Film4+1
#EXTVLCOPT:program=8381
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,260,2315,2313,2311
#EXTINF:-1,Food Network
#EXTVLCOPT:program=53220
rtsp://SATIPADDRESS/?src=1&freq=11597&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,265,2309,2329,2323
#EXTVLCOPT:program=2910
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,271,2352,2354,2353
#EXTINF:-1,Food Netwrk+1
#EXTVLCOPT:program=2912
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,268,2319,2321,2320
#EXTINF:-1,FRANCE 24 HD
#EXTVLCOPT:program=52573
rtsp://SATIPADDRESS/?src=1&freq=11426&msys=dvbs2&plts=off&fec=89&pol=v&ro=0.35&sr=29500&mtype=qpsk&pids=0,16,17,20,261,2313,2314
#EXTINF:-1,G! romance+1
#EXTVLCOPT:program=53325
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,283,2317,2330,2318
#EXTINF:-1,GB News HD
#EXTVLCOPT:program=50241
rtsp://SATIPADDRESS/?src=1&freq=11670&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,259,2305,2313,2306
#EXTINF:-1,Gems TV
#EXTVLCOPT:program=50347
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,277,2327,2331
#EXTINF:-1,GEO News
#EXTVLCOPT:program=50395
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,267,2351,2352
#EXTINF:-1,GEO TV
#EXTVLCOPT:program=50394
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,281,2315,2316
#EXTINF:-1,GOD Channel
#EXTVLCOPT:program=54054
rtsp://SATIPADDRESS/?src=1&freq=11656&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,257,2315,2316
#EXTINF:-1,GREAT! action
#EXTVLCOPT:program=53310
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,269,2306,2327,2307
#EXTINF:-1,GREAT! movies
#EXTVLCOPT:program=53300
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,260,2308,2312,2309
#EXTVLCOPT:program=53315
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,270,2349,2328,2350
#EXTINF:-1,GREAT! movies+1
#EXTVLCOPT:program=53355
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,271,2352,2331,2353
#EXTINF:-1,GREAT! romance
#EXTVLCOPT:program=53148
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,257,2307,2310,2308
#EXTVLCOPT:program=53320
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,284,2313,2329,2314
#EXTINF:-1,GREAT! tv
#EXTVLCOPT:program=53305
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,259,2304,2326,2305
#EXTVLCOPT:program=53375
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,265,2341,2335,2342
#EXTINF:-1,GREAT! tv+1
#EXTVLCOPT:program=53380
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,256,2344,2336,2345
#EXTINF:-1,GREAT!action+1
#EXTVLCOPT:program=53365
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,268,2319,2332,2320
#EXTINF:-1,HGTV
#EXTVLCOPT:program=52420
rtsp://SATIPADDRESS/?src=1&freq=11038&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,262,2374,2377,2375
#EXTINF:-1,HGTV
#EXTVLCOPT:program=2917
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,258,2395,2397,2382
#EXTINF:-1,HGTV+1
#EXTVLCOPT:program=53230
rtsp://SATIPADDRESS/?src=1&freq=11597&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,268,2330,2339,2333
#EXTINF:-1,High Street TV 1
#EXTVLCOPT:program=54175
rtsp://SATIPADDRESS/?src=1&freq=11567&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,261,2344,2345
#EXTINF:-1,High Street TV 2
#EXTVLCOPT:program=55102
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,273,2352,2353
#EXTINF:-1,High Street TV 3
#EXTVLCOPT:program=55104
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,266,2338,2339
#EXTINF:-1,HobbyMakerHD
#EXTVLCOPT:program=50486
rtsp://SATIPADDRESS/?src=1&freq=11112&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,265,2325,2326
#EXTINF:-1,HUM EUROPE
#EXTVLCOPT:program=55181
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,285,2341,2340
#EXTINF:-1,HUM Masala
#EXTVLCOPT:program=55146
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,281,2343,2342
#EXTINF:-1,Ideal World HD
#EXTVLCOPT:program=50480
rtsp://SATIPADDRESS/?src=1&freq=11112&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,259,2314,2316
#EXTINF:-1,India Today
#EXTVLCOPT:program=50382
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,273,2332,2330
#EXTINF:-1,iON TV
#EXTVLCOPT:program=55276
rtsp://SATIPADDRESS/?src=1&freq=11508&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,257,2309,2306
#EXTINF:-1,IQRA Bangla
#EXTVLCOPT:program=53153
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,259,2324,2325
#EXTINF:-1,IQRA TV
#EXTVLCOPT:program=53152
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,258,2322,2323
#EXTINF:-1,Islam Bangla
#EXTVLCOPT:program=54052
rtsp://SATIPADDRESS/?src=1&freq=11656&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,263,2311,2312
#EXTINF:-1,Islam Ch Urdu
#EXTVLCOPT:program=52130
rtsp://SATIPADDRESS/?src=1&freq=11265&msys=dvbs&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,259,2312,2315
#EXTINF:-1,Islam Channel
#EXTVLCOPT:program=52123
rtsp://SATIPADDRESS/?src=1&freq=11265&msys=dvbs&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,257,2309,2310
#EXTINF:-1,Islam TV
#EXTVLCOPT:program=53154
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,261,2326,2327
#EXTINF:-1,ITV Be HD
#EXTVLCOPT:program=20835
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,260,2335,2338,2336
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=21040
rtsp://SATIPADDRESS/?src=1&freq=11344&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,256,2310,2312,2311
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=21010
rtsp://SATIPADDRESS/?src=1&freq=11344&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,259,2331,2334,2332
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=21015
rtsp://SATIPADDRESS/?src=1&freq=11344&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,258,2305,2308,2306
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=21070
rtsp://SATIPADDRESS/?src=1&freq=11344&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,257,2315,2318,2316
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=21080
rtsp://SATIPADDRESS/?src=1&freq=11344&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,260,2320,2323,2321
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=21060
rtsp://SATIPADDRESS/?src=1&freq=11344&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,261,2329,2338,2335
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=21000
rtsp://SATIPADDRESS/?src=1&freq=11344&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,264,2339,2342,2340
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=20750
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,257,2318,2316,2317
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=20760
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,259,2310,2312,2314
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=20770
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,261,2325,2328,2326
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=20720
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,262,2335,2338,2336
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=20700
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,264,2339,2342,2340
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=20740
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,260,2330,2333,2331
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=20840
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,258,2325,2329,2327
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=20850
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,257,2310,2318,2311
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=20820
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,256,2320,2321,2322
#EXTINF:-1,ITV1 HD
#EXTVLCOPT:program=20830
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,264,2339,2342,2340
#EXTINF:-1,ITV1 Wales HD
#EXTVLCOPT:program=20730
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,256,2320,2323,2321
#EXTINF:-1,ITV1+1
#EXTVLCOPT:program=55269
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,282,2380,2382,2381
#EXTINF:-1,ITV1+1
#EXTVLCOPT:program=55270
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,280,2367,2370,2368
#EXTINF:-1,ITV1+1
#EXTVLCOPT:program=55268
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,281,2372,2378,2377
#EXTINF:-1,ITV1+1
#EXTVLCOPT:program=55271
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,266,2384,2387,2385
#EXTINF:-1,ITV2 HD
#EXTVLCOPT:program=20710
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,258,2305,2309,2307
#EXTINF:-1,ITV2+1
#EXTVLCOPT:program=55281
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,267,2389,2392,2390
#EXTINF:-1,ITV3 HD
#EXTVLCOPT:program=21050
rtsp://SATIPADDRESS/?src=1&freq=11344&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,262,2314,2328,2326
#EXTINF:-1,ITV3+1
#EXTVLCOPT:program=55282
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,269,2394,2397,2395
#EXTINF:-1,ITV4 HD
#EXTVLCOPT:program=20825
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,262,2330,2334,2332
#EXTINF:-1,ITV4+1
#EXTVLCOPT:program=55283
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,274,2317,2325,2320
#EXTINF:-1,JewelleryMaker
#EXTVLCOPT:program=54116
rtsp://SATIPADDRESS/?src=1&freq=11567&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,262,2563,2564
#EXTINF:-1,Kanshi TV
#EXTVLCOPT:program=55155
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,279,2327,2345
#EXTINF:-1,LEGEND
#EXTVLCOPT:program=55209
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,277,2644,2645
#EXTINF:-1,LEGEND XTRA
#EXTVLCOPT:program=55202
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,286,2307,2308
#EXTINF:-1,LEGEND XTRA+1
#EXTVLCOPT:program=55218
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,276,2314,2315
#EXTINF:-1,LoveWorld HD
#EXTVLCOPT:program=50255
rtsp://SATIPADDRESS/?src=1&freq=11670&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,262,2311,2312
#EXTINF:-1,Madani Chnl
#EXTVLCOPT:program=54056
rtsp://SATIPADDRESS/?src=1&freq=11656&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,259,2319,2320
#EXTINF:-1,MATV National
#EXTVLCOPT:program=55122
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,268,2367,2368
#EXTINF:-1,More4
#EXTVLCOPT:program=8383
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,273,2381,2383,2380
#EXTINF:-1,More4+1
#EXTVLCOPT:program=8366
rtsp://SATIPADDRESS/?src=1&freq=10936&msys=dvbs2&plts=off&fec=34&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,258,2305,2308,2306
#EXTINF:-1,MstHveIdeasHD
#EXTVLCOPT:program=50482
rtsp://SATIPADDRESS/?src=1&freq=11112&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,257,2306,2317
#EXTINF:-1,MTA1 World HD
#EXTVLCOPT:program=53151
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,256,2305,2313
#EXTINF:-1,Music India
#EXTVLCOPT:program=22312
rtsp://SATIPADDRESS/?src=1&freq=11493&msys=dvbs&plts=off&fec=56&pol=h&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,264,2317,2318
#EXTINF:-1,NDTV World
#EXTVLCOPT:program=55116
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,269,2360,2361
#EXTINF:-1,New Vision TV
#EXTVLCOPT:program=55121
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,262,2365,2366
#EXTINF:-1,NHK World HD
#EXTVLCOPT:program=53147
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,274,2315,2317
#EXTINF:-1,Noor TV
#EXTVLCOPT:program=55109
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,264,2355,2356
#EXTINF:-1,NOW 70s
#EXTVLCOPT:program=50321
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,274,2317,2322
#EXTINF:-1,NOW 80s
#EXTVLCOPT:program=50306
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,257,2360,2361
#EXTINF:-1,NOW 90s & 00s
#EXTVLCOPT:program=54160
rtsp://SATIPADDRESS/?src=1&freq=11567&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,258,2308,2309
#EXTINF:-1,NOW ROCK
#EXTVLCOPT:program=55114
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,261,2560,2561
#EXTINF:-1,NTD
#EXTVLCOPT:program=55106
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,257,2306,2307
#EXTINF:-1,NTV
#EXTVLCOPT:program=54221
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,256,2358,2359
#EXTINF:-1,Panjab TV
#EXTVLCOPT:program=7615
rtsp://SATIPADDRESS/?src=1&freq=11523&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,261,2323,2324
#EXTINF:-1,PBC
#EXTVLCOPT:program=54055
rtsp://SATIPADDRESS/?src=1&freq=11656&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,258,2317,2318
#EXTINF:-1,PBS America
#EXTVLCOPT:program=55213
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,264,2373,2375,2374
#EXTINF:-1,PCNE Chinese HD
#EXTVLCOPT:program=7100
rtsp://SATIPADDRESS/?src=1&freq=11641&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,256,2305,2306
#EXTINF:-1,Pitaara
#EXTVLCOPT:program=7614
rtsp://SATIPADDRESS/?src=1&freq=11523&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,260,2331,2332
#EXTINF:-1,PoliticsPunjab
#EXTVLCOPT:program=7605
rtsp://SATIPADDRESS/?src=1&freq=11523&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,273,2321,2322
#EXTINF:-1,POP
#EXTVLCOPT:program=53340
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,280,2315,2316
#EXTINF:-1,POP Max
#EXTVLCOPT:program=53350
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,278,2337,2338
#EXTINF:-1,POP Max+1
#EXTVLCOPT:program=53360
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,276,2333,2334
#EXTINF:-1,POP+1
#EXTVLCOPT:program=53370
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,273,2339,2340
#EXTINF:-1,PTC PUNJABI
#EXTVLCOPT:program=54211
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,260,2312,2313
#EXTINF:-1,QTV Religious
#EXTVLCOPT:program=50365
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,262,2312,2313
#EXTINF:-1,QUEST
#EXTVLCOPT:program=6213
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,263,2364,2366,2365
#EXTINF:-1,QUEST HD
#EXTVLCOPT:program=2920
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,272,2403,2406,2404
#EXTINF:-1,Quest Red
#EXTVLCOPT:program=52450
rtsp://SATIPADDRESS/?src=1&freq=11038&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,278,2319,2322,2320
#EXTVLCOPT:program=6214
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,265,2356,2359,2357
#EXTINF:-1,Quest Red+1
#EXTVLCOPT:program=6211
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,259,2323,2346,2343
#EXTINF:-1,QUEST+1
#EXTVLCOPT:program=6215
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,264,2360,2363,2361
#EXTINF:-1,QVC Beauty
#EXTVLCOPT:program=22303
rtsp://SATIPADDRESS/?src=1&freq=11493&msys=dvbs&plts=off&fec=56&pol=h&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,262,2309,2310
#EXTINF:-1,QVC Extra
#EXTVLCOPT:program=22301
rtsp://SATIPADDRESS/?src=1&freq=11493&msys=dvbs&plts=off&fec=56&pol=h&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,261,2307,2308
#EXTINF:-1,QVC HD
#EXTVLCOPT:program=22305
rtsp://SATIPADDRESS/?src=1&freq=11493&msys=dvbs&plts=off&fec=56&pol=h&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,256,2311,2312
#EXTINF:-1,QVC Style HD
#EXTVLCOPT:program=22306
rtsp://SATIPADDRESS/?src=1&freq=11493&msys=dvbs&plts=off&fec=56&pol=h&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,258,2315,2316
#EXTINF:-1,Really
#EXTVLCOPT:program=53236
rtsp://SATIPADDRESS/?src=1&freq=11597&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,269,2340,2343,2341
#EXTINF:-1,Really
#EXTVLCOPT:program=2904
rtsp://SATIPADDRESS/?src=1&freq=12382&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=29500&mtype=8psk&pids=0,16,17,20,276,2317,2344,2341
#EXTINF:-1,revelation
#EXTVLCOPT:program=54066
rtsp://SATIPADDRESS/?src=1&freq=11656&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,262,2340,2341
#EXTINF:-1,Rewind TV
#EXTVLCOPT:program=50327
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,275,2338,2339
#EXTINF:-1,S4C
#EXTVLCOPT:program=52575
rtsp://SATIPADDRESS/?src=1&freq=11426&msys=dvbs2&plts=off&fec=89&pol=v&ro=0.35&sr=29500&mtype=qpsk&pids=0,16,17,20,263,2315,2325,2323
#EXTINF:-1,S4C HD
#EXTVLCOPT:program=52565
rtsp://SATIPADDRESS/?src=1&freq=11426&msys=dvbs2&plts=off&fec=89&pol=v&ro=0.35&sr=29500&mtype=qpsk&pids=0,16,17,20,258,2340,2344,2342
#EXTINF:-1,Sangat
#EXTVLCOPT:program=54060
rtsp://SATIPADDRESS/?src=1&freq=11656&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,279,2327,2328
#EXTINF:-1,Sanskar
#EXTVLCOPT:program=54223
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,259,2309,2318
#EXTINF:-1,Sikh Channel
#EXTVLCOPT:program=50335
rtsp://SATIPADDRESS/?src=1&freq=11082&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,264,2307,2308
#EXTINF:-1,Sky Arts
#EXTVLCOPT:program=6752
rtsp://SATIPADDRESS/?src=1&freq=12148&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,264,528,587,666
#EXTINF:-1,Sky Intro
#EXTVLCOPT:program=1002
rtsp://SATIPADDRESS/?src=1&freq=12324&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,256,512,662
#EXTVLCOPT:program=1003
rtsp://SATIPADDRESS/?src=1&freq=12324&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,260,512,662
#EXTVLCOPT:program=1004
rtsp://SATIPADDRESS/?src=1&freq=12324&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,265,512,662
#EXTINF:-1,Sky Mix HD
#EXTVLCOPT:program=5052
rtsp://SATIPADDRESS/?src=1&freq=12168&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,258,521,584,657
#EXTVLCOPT:program=5831
rtsp://SATIPADDRESS/?src=1&freq=12226&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,256,521,583,654
#EXTINF:-1,Sky News
#EXTVLCOPT:program=7404
rtsp://SATIPADDRESS/?src=1&freq=11934&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,296,514,582,653,8190
#EXTINF:-1,Sky News
#EXTVLCOPT:program=6406
rtsp://SATIPADDRESS/?src=1&freq=12090&msys=dvbs2&plts=off&fec=89&pol=v&ro=0.35&sr=29500&mtype=qpsk&pids=0,16,17,20,263,524,588,653
#EXTINF:-1,Sky RB
#EXTVLCOPT:program=1641
rtsp://SATIPADDRESS/?src=1&freq=12324&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,259,512,662
#EXTINF:-1,SkyNewsArabia
#EXTVLCOPT:program=7645
rtsp://SATIPADDRESS/?src=1&freq=12090&msys=dvbs2&plts=off&fec=89&pol=v&ro=0.35&sr=29500&mtype=qpsk&pids=0,16,17,20,258,515,643
#EXTINF:-1,SonLife
#EXTVLCOPT:program=55120
rtsp://SATIPADDRESS/?src=1&freq=11552&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,277,2331,2328,2330
#EXTINF:-1,STV
#EXTVLCOPT:program=55265
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,278,2330,2349,2329
#EXTINF:-1,STV
#EXTVLCOPT:program=55266
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,279,2362,2365,2363
#EXTINF:-1,STV HD
#EXTVLCOPT:program=20800
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,261,2305,2308,2306
#EXTINF:-1,STV HD
#EXTVLCOPT:program=5168
rtsp://SATIPADDRESS/?src=1&freq=12168&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,261,517,581,642
#EXTINF:-1,Takbeer TV
#EXTVLCOPT:program=54145
rtsp://SATIPADDRESS/?src=1&freq=11567&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,263,2347,2348
#EXTINF:-1,TalkingPictures
#EXTVLCOPT:program=55225
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,268,2300,2302,2301
#EXTINF:-1,TBN UK
#EXTVLCOPT:program=52124
rtsp://SATIPADDRESS/?src=1&freq=11265&msys=dvbs&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,256,2363,2364
#EXTINF:-1,That's Dance
#EXTVLCOPT:program=54151
rtsp://SATIPADDRESS/?src=1&freq=11567&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,270,2313,2307
#EXTINF:-1,That's Melody
#EXTVLCOPT:program=55280
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,258,2322,2323
#EXTINF:-1,That's Oldies
#EXTVLCOPT:program=55207
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,259,2352,2326
#EXTINF:-1,That's TV
#EXTVLCOPT:program=55230
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,271,2357,2356
#EXTINF:-1,That's TV 2
#EXTVLCOPT:program=55201
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,256,2316,2318
#EXTINF:-1,That's TV 3
#EXTVLCOPT:program=55235
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,272,2359,2358
#EXTINF:-1,Tiny Pop
#EXTVLCOPT:program=53335
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,261,2310,2311
#EXTINF:-1,Tiny Pop+1
#EXTVLCOPT:program=53385
rtsp://SATIPADDRESS/?src=1&freq=11307&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,262,2324,2325
#EXTINF:-1,TJC HD
#EXTVLCOPT:program=52570
rtsp://SATIPADDRESS/?src=1&freq=11426&msys=dvbs2&plts=off&fec=89&pol=v&ro=0.35&sr=29500&mtype=qpsk&pids=0,16,17,20,260,2307,2308
#EXTINF:-1,Together
#EXTVLCOPT:program=6872
rtsp://SATIPADDRESS/?src=1&freq=12148&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,260,513,641
#EXTINF:-1,Travelxp
#EXTVLCOPT:program=22313
rtsp://SATIPADDRESS/?src=1&freq=11493&msys=dvbs&plts=off&fec=56&pol=h&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,257,2319,2320
#EXTINF:-1,TRT World
#EXTVLCOPT:program=54051
rtsp://SATIPADDRESS/?src=1&freq=11656&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,273,2307,2308
#EXTINF:-1,TRT World HD
#EXTVLCOPT:program=55273
rtsp://SATIPADDRESS/?src=1&freq=11508&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,256,2320,2322
#EXTINF:-1,TRUE CRIME
#EXTVLCOPT:program=55214
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,285,2650,2346,2651
#EXTINF:-1,TRUE CRIME X
#EXTVLCOPT:program=50903
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,270,3080,3081
#EXTINF:-1,TRUE CRIME+1
#EXTVLCOPT:program=55217
rtsp://SATIPADDRESS/?src=1&freq=11343&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,275,2312,2347,2313
#EXTINF:-1,TV One
#EXTVLCOPT:program=54226
rtsp://SATIPADDRESS/?src=1&freq=11225&msys=dvbs&plts=off&fec=23&pol=h&ro=0.35&sr=27500&mtype=qpsk&pids=0,16,17,20,264,2307,2308
#EXTINF:-1,TV Warehouse
#EXTVLCOPT:program=54180
rtsp://SATIPADDRESS/?src=1&freq=11567&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,265,2330,2331
#EXTINF:-1,TVC News
#EXTVLCOPT:program=54064
rtsp://SATIPADDRESS/?src=1&freq=11656&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=22000&mtype=qpsk&pids=0,16,17,20,283,2336,2337
#EXTINF:-1,U&Dave
#EXTVLCOPT:program=6506
rtsp://SATIPADDRESS/?src=1&freq=12129&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,264,2308,2310,2312
#EXTINF:-1,U&DaveJaVu
#EXTVLCOPT:program=25114
rtsp://SATIPADDRESS/?src=1&freq=12129&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,277,2345,2344,2346
#EXTINF:-1,U&Drama
#EXTVLCOPT:program=6522
rtsp://SATIPADDRESS/?src=1&freq=12129&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,257,2372,2375,2373
#EXTINF:-1,U&Drama+1
#EXTVLCOPT:program=25113
rtsp://SATIPADDRESS/?src=1&freq=12129&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,268,2380,2383,2381
#EXTINF:-1,U&Eden
#EXTVLCOPT:program=6502
rtsp://SATIPADDRESS/?src=1&freq=12129&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,260,2317,2318,2319
#EXTINF:-1,U&Eden+1
#EXTVLCOPT:program=25103
rtsp://SATIPADDRESS/?src=1&freq=12129&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,274,2305,2306,2307
#EXTINF:-1,U&W
#EXTVLCOPT:program=6520
rtsp://SATIPADDRESS/?src=1&freq=12129&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,270,2363,2364,2365
#EXTINF:-1,U&W+1
#EXTVLCOPT:program=25110
rtsp://SATIPADDRESS/?src=1&freq=12129&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,273,2354,2357,2355
#EXTINF:-1,U&Yesterday
#EXTVLCOPT:program=6505
rtsp://SATIPADDRESS/?src=1&freq=12129&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,263,2332,2333,2334
#EXTINF:-1,U&Yesterday+1
#EXTVLCOPT:program=25116
rtsp://SATIPADDRESS/?src=1&freq=12129&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,279,2337,2338,2339
#EXTINF:-1,UTV HD
#EXTVLCOPT:program=20810
rtsp://SATIPADDRESS/?src=1&freq=11386&msys=dvbs2&plts=off&fec=23&pol=v&ro=0.35&sr=27500&mtype=8psk&pids=0,16,17,20,259,2312,2315,2313
#EXTINF:-1,WION HD
#EXTVLCOPT:program=7101
rtsp://SATIPADDRESS/?src=1&freq=11641&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,259,2311,2313
#EXTINF:-1,Xpanded TV
#EXTVLCOPT:program=7607
rtsp://SATIPADDRESS/?src=1&freq=11523&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=23000&mtype=8psk&pids=0,16,17,20,275,2325,2326
@neild7744 @GeoffT & @Jean0987654321
Just a brief acknowledgment and thank you for your helpful responses and file, Neil. I’ve got a busy few days now and shall reply properly when I’ve done some more testing and more importantly whether I decide to continue down the Sat>IP path.
Have a good week, Steve
You can also use SLM to add any channels that's gone missing and map it accordingly to gracenote (and use your own channel number to boot too if you want)
https://community.getchannels.com/t/release-playlist-manager-for-channels-streaming-library-manager-extension/41719/154
