Requested Fix - Top Banner Covers Info on the Guide
On version 3.1.7 (and I believe the behavior was the same in prior versions), when the top banner or menu bar for On Now Guide Recordings DVR Search Settings is displayed, it covers up the top part of the TV Program tile and larger boldface title that sits above the details for the program.
Recommend shifting the whole page down so that it does not get covered. The left side menu of All Channels, HD Channels, SD Channels, Favorites, Movies, Sports,Drama, News and Kids looks like it can easily be shifted down to accommodate the extra room needed so things don’t covered up by the top menu bar.
Thank you…I love this app!
Did you see this Aman?
What you are pointing out works as intended. Nobody else wants their screen shifting to pull down a Menu overlay.
Looks odd to me, especially since none of the other pages have the same issue. But if nobody else is concerned about it, I won’t loose any sleep over it.
The initial version we built did move up and down to remain visible, but it felt janky and didn’t work very well. So we are stuck with what we have now. I agree it’s not ideal.
Thank you for the reply
