I had to completely restore my iMac from Time Machine which had the Channels server on it. After restoring, I tried to access Channels but I get an error in my browser saying it wasn't found.
Do I need to completely re-install Channels?
I just tried to reinstall, and it says that the server is already running.
What's the URL I need to use to see the server?
Can you select the uninstall option in the installer first?
Others have reported a reinstall is required after Time Machine restore.
If the dvr is running it will be at http://127.0.0.1:8089 and if you reinstall you should use http://127.0.0.1:8089/restore
Okay, thanks. Neither of those URLs work so let me re-install. Thanks.
I uninstalled and then re-installed and then did the restore URL. All seems to be working. Thanks!
