In the last couple weeks using Hulu-live as my base I no longer get the local FOX channel to appear in my guide… any clues as to what is going on???
I did have to login with my provider Hulu and everything appears to work but FOX 4 Dallas / Ft Worth… it does not respond.
It also doesn’t appear in the programming guide any more.
I lost Fox using Spectrum and Dish a couple of weeks ago. Using a suggestion I found on some of the community posts, I went to settings in the DVR server. Scroll to the bottom section "Experimental."
Uncheck "Local networks via TV Everywhere." Close your server. Restart your servicer. Then check
"Local networks via TV Everywhere." You may have to restart the server after this. Can't recall.
Fox returned on both Spectrum and Dish.
Hope this works for you!
It did and it fixed the issue. I was advised to try that yesterday… but thanks!
