This i know, but how does one acces that source? Is it private? API only thing?
One can go to TVdb or MovieDB etc and access their database outside of Plex or Emby etc. And there is posts about metadata matching using tvDB in Channels before.
For custom channels via m3u, far as i have understood it, the only metadata for guide input is through external xml, so I am not seeing how the built in Guide selector used for OTA and TVE works for this feature since it works by zip code selection, which is not applicable to these FAST channels.
The option to "Change provider" only give me those zip code provided options "OTA Lineup or Digital Cable Lineup, or "Existing" XML/X-M3U, or Custom URL.
this is what comes up when i try to channel mapping for a channel, and searching for the channel name only searches the linked to xml:
What you stated meant to me that you mapped this not to the Samsung XML but to Channels own Guide, which uses Gracenote... How do you do that?
