I've had the same issue today.
Check the XLMTV guide data you're pulling
first line has the timestamp (Unix epoch time) when it was generated generated-ts="1755674545"
If it's been more than a few hours since it was generated, ping Matt and let him know
@matthuisman
Guide data ran out again today.
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE tv SYSTEM "xmltv.dtd"><tv generator-info-name="www.matthuisman.nz" generated-ts="1755674545">
Last generated Wednesday, August 20, 2025 07:22:25 UTC (12 hours ago)
Channels are still streaming.
P.S. it's now 8AM Thursday in NZ
their api changed sometime yesterday so the script can't run at all until i find time to find the new method (hopefully tonight)
may have been something their end as the api started working again without me changing it
Anyone else having any issues with the content playing? I have had no issues accessing content until the last few days, but videos no longer play. Any assistance is appreciated.
I am using it through docker, can access the :8182 port through my browser, can access the m3u and epg with no issues. It just creates an error when trying to play videos.
Check your container logs and server logs to see if they tell you anything. You might try to restart the container and see if that helps. They are working for me, but that really doesn't mean much.
Edit: I checked the UK feed too and it worked also.
looks like the user hasnt read the comments above about updating to latest docker
his is using old urls
Nevermind, I pulled via the command line as Matt suggested above. It worked perfectly. Apparently, when I recreated in portainer it was not pulling the latest docker. thx.
update: I pulled via the command line as Matt suggested above. It worked perfectly. Apparently, when I recreated in portainer it was not pulling the latest docker. thx.
hello all. works good for me right off the bat. although im not getting a link for a channel i want. i specifically am looking for channel 1501 STN (Samsung Television Network)
Some Samsung channels are using Widevine and not able to be played back in Channels.
STN is one of those:
It's unfortunate but yeah STN will have to be piped in with a HDMI encoder.
unfortunately i cant even get that to work, I've tried for days. the only way i can get it to display is screensharing my phone to a Onn 4k tv, or a Roku but it looks rough compared to my s25/s8+ tab. when i do the built in app casting most channels don't even play and only show the Samsung TV+ logo. it tries to "load" the show for a few sec then logo forever. and a similar thing happens when i use a usbc to HDMI cable it just tries to load channel a few times then says something to the effect of not being able to connect to channel.
CC: @matthuisman
my on only solution-ish that seems to work. the only samsung out of 4 of mine, and some family members that work (tab s8+, fold3, s25U, A23 freebie, brothers s9+) is my S25U, and the solution is to screen view cast to a roku, and that's the only combo that works. otherwise i get a endless loading channel on a tv, the phone says cannot load this channel, or i get a black feed in the video frame. the kicker with the roku is even with the phone and wifi AP a couple feet away, the thing will randomly dissconnect or freeze for up to 5 sec then speed up like 300x to catch back up.
Is it just a me thing, or has the linked generation stopped working; went to go watch a show this morning and the channels were just blank
Restart the docker container and try again.
If it fails, check the container log.
Disregard.....user error.
Sorry if this has been addressed previously, but I'm getting this error when I try and install in Portainer Stack:
Failed to deploy a stack: compose up operation failed: Error response from daemon: pull access denied for matthuisman/samsungtv, repository does not exist or may require 'docker login'
Check out Matt's repo and website and make sure you are using the correct image.
@matthuisman
Samsung TV Plus xml guide data is now 16 hours old
<tv generator-info-name="www.matthuisman.nz" generated-ts="1773032949">
Last generated Monday, March 9, 2026 at 5:09:09 AM GMT
thanks. looks like they have made a change. ill try investigate tonight
