Cloudflare continuing to have issues and no responses to my posts..
So for now, I have moved the .json.gz's to Github and redirect to them.
Just pushed a new docker container that
- uses the .json.gz for app data
- caches the json and epg data for 5mins
- redid the status page to show the playlist and epg urls for each region
if you just use a single region, you can use the epg.xml?regions=us and it will download just the
smaller us only xml. If you specify no region or more than one - itll just use the all xml.
