Saorview and Freeview EPG
Just wondering if anyone receives both Saorview and Freeview and how it handles the EPG on the DVR.
I live in Northern Ireland and currently get Freeview but have quite an old aerial so I’m wondering if I should also invest in an Aerial that receives both Freeview and Saorview how Channels handles it.
Just started using Channels but I’ve been using getting Saorview and Freeview in Plex for a few months now and it works great. No EPG like Channels and that’s where Channels has the big advantage so hoping they add support for the likes of HRTunerProxy.
Thanks, what is HRTunerproxy?
I’ve used Plex too but definitely find Channels much better and more reliable. I found Plex very slow when changing stations.
Did you get channels working with both Saorview & Freeview in the same guide?
I’ve only started using Channels but so far it won’t recognise my freeview box. HRTunerProxy is a plugin for Enigma2 Satellite boxes that broadcasts a signal similar to the way a HDHomeRun does over the network.
Plex is able to pick up both my HDHomeRun and Enigma2 Satellite box and I have all the Irish and UK free channels.
But now I think I realise what you are trying to do, do you have 2 HDHomeruns or just 1?
I just have one HDHOMERUN. My aerial is a bit flaky so I’m going to replace it but thinking of getting both an aerial for Freeview and saorview. I was hoping to Y them both into the hdhomerun.
Under your HDHR on the DVR’s settings web page, you can click the pencil icon and map channels to the correct guide data. You should be able to poke around in there and see if there are guide entries available for the Saorview channels. I believe they are in there, but if not let me know your postal code and I will contact our guide provider to have them added.
Thanks for the advice. I think I’ll go ahead and get the new aerials installed and play about with this.
If it works I’ll post my findings here.
