Hi,
New to channels DVR - was hoping I could save to a network drive, but I don’t see my drive listed? I mapped it as V: in Windows 10.
Hi,
Recording to a network drive is strongly discouraged… the video streams from the HDHR are already quite large, and recording to the network means 2x the bandwidth requirements.
However you’re free to try it out if you want. Just put v:\DVR into the box and check the DVR to start it.
This bug has been fixed, so network drives will now appear in the list of options. Thanks for reporting the issue.
