Second time this has happened. Looks like a timing issue.
Recording completes successfully, connection closes, then error appears.
2025/01/03 11:59:30.003255 [DVR] Starting job 1735934370-105 Ancient Mysteries With Leonard Nimoy on ch=[9026]
2025/01/03 11:59:31.365328 [TNR] Opened connection to M3U-frndlyTV for ch9026 Story Television
2025/01/03 11:59:31.389144 [DVR] Recording for job 1735934370-105 from M3U-frndlyTV ch9026 into "TV/Ancient Mysteries With Leonard Nimoy/Ancient Mysteries With Leonard Nimoy 2025-01-03 The Lost Treasure of the 2025-01-03-1159.mpg" for 1h1m29.966317135s
2025/01/03 11:59:31.740886 [IDX] Generating video index for job 1735934370-105
2025/01/03 13:01:21.044866 [TNR] Closed connection to M3U-frndlyTV for ch9026 Story Television
2025/01/03 13:01:21.383409 [SNR] Buffer statistics for "TV/Ancient Mysteries With Leonard Nimoy/Ancient Mysteries With Leonard Nimoy 2025-01-03 The Lost Treasure of the 2025-01-03-1159.mpg": buf=0% drop=0%
2025/01/03 13:01:21.383498 [SNR] Streaming statistics for "TV/Ancient Mysteries With Leonard Nimoy/Ancient Mysteries With Leonard Nimoy 2025-01-03 The Lost Treasure of the 2025-01-03-1159.mpg": timeouts=0 segment_timeouts=0 playlist_timeouts=0
2025/01/03 13:01:21.485601 [MTS] Statistics for "TV/Ancient Mysteries With Leonard Nimoy/Ancient Mysteries With Leonard Nimoy 2025-01-03 The Lost Treasure of the 2025-01-03-1159.mpg": discontinuity_detected=0 transport_errors=0 saw_pcr=true saw_pmt=true highest_pts=3715.966667
2025/01/03 13:01:21.547113 [DVR] Error running job 1735934370-105 Ancient Mysteries With Leonard Nimoy: Could not fetch playlist: https://sr-live-weigel1.akamaized.net/v1/manifest/840a24ccd7c75076211d060179b3ad0c64fdc6ca/weigel_movies_nr_rt_new/149b1753-12e4-4e16-ad7d-5736f07a28f4/hdntl=exp=1736020770~acl=%2f*~data=hdntl~hmac=915beb4f6e9c24090b30da808c5a3cebf9ac9847a50e437c9029d704bc3f0b03/1.m3u8: Get "https://sr-live-weigel1.akamaized.net/v1/manifest/840a24ccd7c75076211d060179b3ad0c64fdc6ca/weigel_movies_nr_rt_new/149b1753-12e4-4e16-ad7d-5736f07a28f4/hdntl=exp=1736020770~acl=%2f*~data=hdntl~hmac=915beb4f6e9c24090b30da808c5a3cebf9ac9847a50e437c9029d704bc3f0b03/1.m3u8": Stream closed
2025/01/03 13:01:22.704854 [DVR] Processing file-2885: TV/Ancient Mysteries With Leonard Nimoy/Ancient Mysteries With Leonard Nimoy 2025-01-03 The Lost Treasure of the 2025-01-03-1159.mpg
2025/01/03 13:01:23.436343 [IDX] Generating video index for file-2885: TV/Ancient Mysteries With Leonard Nimoy/Ancient Mysteries With Leonard Nimoy 2025-01-03 The Lost Treasure of the 2025-01-03-1159.mpg
2025/01/03 13:01:23.514586 [DVR] Running commercial detection on file 2885 (TV/Ancient Mysteries With Leonard Nimoy/Ancient Mysteries With Leonard Nimoy 2025-01-03 The Lost Treasure of the 2025-01-03-1159.mpg)
2025/01/03 13:01:40.776599 [IDX] Finished video index generation for file-2885 in 17s
Start time 11:59:31.389144
+ Recording time 01:01:29.966317135
= Finish time 13:01:01.355461135
Closed connection 13:01:21.044866
Error logged 13:01:21.547113
highest_pts=3715.966667 says it recorded for 01:01:55.966667
My video editor says the recorded duration is 01:01:55.96
