Scanner error walking external hard drive with movies
So I have new Mac mini m1 and I have external drive with just movies and was working but now. In log. Scanner error walking.
I rebooted Mac mini still not working
95b4b915-482b-4b94-9f9a-4f5289d2625a
Maybe you can delete the directory it's complaining about?
2021/06/27 18:35:08.261531 [ERR] Scanner error walking /Volumes/Movies 1: open /Volumes/Movies 1/.DocumentRevisions-V100: operation not permitted
There is no folder in there
It starts with a "dot", and is therefore considered hidden. You need to enable display of hidden files to see it in the Finder, or manually delete it from the command line.
ok delete and still nothing
i even reformated drive
what format should i format in mac
shows movies 1 when-it doesn't t exit on pc
I’m guessing maybe it got mapped twice and macOS is automatically appending ā€œ-1ā€ to the end of it?
So i have reformatted drive to exfat and still same issue i delete hidden file and empty trash and comes back
Scanner error walking /Volumes/Movies: open /Volumes/Movies/.Spotlight-V100: operation not permitted
2021/06/27 22:08:05.748732 [ERR] Scanner error walking /Volumes/Movies: open /Volumes/Movies/.Spotlight-V100: operation not permitted
2021/06/27 22:11:19.862982 [ERR] Scanner error walking /Volumes/Movies: open /Volumes/Movies/.Trashes: operation not permitted
481c4835-a626-415c-82e9-fb3af7e8dd8
I guess it doesn't work with exfat then for some reason.
i have tried both exfat and mac format does same then on both
Maybe this will help? https://superuser.com/questions/89556/how-to-disable-creating-spotlight-v100-and-trash-folders-on-external-drive
so think fixed it
i went into system preferences under privacy and enable full write access to channels dvr that seemed to fix problem
even though it said under files and folders that gave access to removable and desktop would give me that error
Ok so it did not work
