Scanning for channels
"scanning for channels" I use 2 HD HomeRun tuner devices; I have 4 Apple TV devices. Do I need to scan for channels on each device? I have a separate computer for the HDHomeRun program; I ran the 'scan for channels of the HomeRun program ... the results/channels, did not show up on the individual Apple TV's (confusing for me). Appreciate any insights that you can share with me.
On the HDHR device web UI make sure the firmware is updated and run the scan from there. It will be saved on the tuner and then all the apps can use that
Thank you
