Sorry I am bombarding the board tonight! Have just found a curious minor bug whereby in the DVR tab on web UI, it shows an episode of a series set to record at 7.19pm this Saturday but in the guide, the same airing is not showing as set to record. tvOS guide shows it set to record, correctly. I had a play and pausing and resuming the pass was enough to trigger it to update and then showed in web UI guide as set to record, without changing anything else.
If you notice this again, try refreshing the browser to see if it fixes the issue.
Ok will do. Though I did navigate away from the guide page and back to it and it still showed up as not set to record. That has the same effect as refreshing, presumably? I will see if I can find the logs for when i paused and resumed the pass and it fixed it, in case that gives any clues.
Navigating back and forth does not refresh the guide recording state. Since it showed up correctly on tvOS and elsewhere, I’m pretty sure it was a refresh issue.
