I have installed this firmware update on my Lacie 5BIG and I can no longer install Channels DVR onto it, worked fine before, is there a solution to this? Will I need/be able to downgrade the firmware or is there A Channels update?
Thanks
What happens when you install??
I get this notification "Error attempting to install com.getchannels.dvr-1.0.11-x86_64.rbw" and no installation.
Can you setup SSH access and connect to run some commands for debugging?
I turned on SSH Access, I'm on a Mac, can you walk me through it?
Terminal?
Yes in Terminal you need to ssh admin@IP or maybe root@IP using the IP of your NAS
Are there any sort of logs or diagnostics you can download from the NAS web UI?
ok, I'm connected, which commands do you want to run?
Log just says Application failed to install
I am sending you a screen share request
There is a diagnostic log to download but a zip file an cannot attach
Done
What does this command output:
rainbow -h
File "/usr/bin/rainbow", line 9, in
load_entry_point('rainbow==1.0', 'console_scripts', 'rainbow')()
File "/usr/lib/python2.7/site-packages/rainbow/cli.py", line 78, in main
import rainbow.lib
File "/usr/lib/python2.7/site-packages/rainbow/lib.py", line 7, in
from rainbow.catalog import Catalog
File "/usr/lib/python2.7/site-packages/rainbow/catalog.py", line 19, in
from rainbow.package import Package, PackageType, PackageState, PackageBlocking, PackageStartupMode, PackageRedirectMode
File "/usr/lib/python2.7/site-packages/rainbow/package.py", line 139, in
class Package(object):
File "/usr/lib/python2.7/site-packages/rainbow/package.py", line 315, in Package
def read_metadata(self, metadata_file, is_extra=False, is_store=False):
File "/usr/lib/python2.7/site-packages/rainbow/lock.py", line 57, in with_database_lock
_filelock_database = FLock(LOCK_FILE_DATABASE)
File "/usr/lib/python2.7/site-packages/rainbow/lock.py", line 12, in init
self.lock_file = open(lock_filename, 'w')
IOError: [Errno 13] Permission denied: '/tmp/rainbow_database.lock'
[admin@NAS ~]$
Please try this package:
https://channels-dvr.s3.amazonaws.com/seagate/com.getchannels.dvr-1.0.12-x86_64.rbw
Boom, you nailed it, that's probably the most efficient tech support I've ever had!
Thanks, it seems all good to go now..
