HI
When selecting Search the search PAD comes up on the left and the cover art on the right side of the Search PAD, as you scroll down and up the cover art will overlap each other.
At one time it was fixed by making the Search PAD transparent allowing the cover art to shift over to the left side allowing the search PAD to still be seen, and used with the navigation pad on the remote.
Was fixed two releases ago.
Thanks
