I just noticed this the other day but none of my season pass recordings are recording. When I try to manually record an episode it also does not record.
Check the Log tab on your DVR web UI to see what errors are shown.
I always forget that the logs are available. I looked at them and search for the error in the forums and found that the HDHomeRun box needed to be restarted.
Thanks
Great, glad you figured it out. What was the error?
