I filled up my first hard drive fairly quickly. I have a 2nd hd, wd 10tb purple, that put some movies on while plugged into my windows 10. Formatted ntfs
I safely removed usb drive from windows. Plugged into 2nd blue usb port on my raspberry pi. I can see movies and shows through both server and clients. I can created folders in the drive..ie Movies or TV.
But I can't move any files from original hd to secondary (to give it more overhead) and I can't move from windows 10 to the 2nd hard drive through network like I can with the first HD.
Says "Destination Folder Access Denied" "you need permission to perform this action"
I'm sure I left off a step in sharing or permissions somewhere but can't figure it out. Maybe inheritance or something.
Any help is appreciated, TIA!
