Remove this line.
Thanks for the suggestions @chDVRuser and @racameron . I made those changes of removing the network=host and the CHANNELS_PORT parameter.
I can now connect to the localhost:8089/admin page, but my AppleTv client can no longer connect.
If you're not using host mode networking, you need to specify the port mapping with -p 8089:8089
Thanks for the reply. When I specify network=host option, and remove the -p 8089 mapping, I can not connect the localhost admin page.
If I remove the network=host option, and add the mapping -p 8089:8089, I can connect to the localhost admin page, but my AppleTv channels client can not connect (See message "Channels DVR server was not found at 192.168.1.x.)
Are you using a browser on another device on your LAN?
Try using this in the docker run command -p 192.168.1.x:8089:8089
Of course, replace the .x with the real local IP address of the docker host.
Not sure why you don't show it since it's a private IP address.
Frankly, I'm quite surprised at the hasty solution. I don't use Channels externally, but now I'm going to be negatively affected because people don't know how to use iptables, reverse proxy, etc?
Or is it that Channels isn't taking into account all the HTTP Headers that can factor in?
Or both?
Clearly the implemented "fix" isn't only going to affect admin portal access... which was the initial reporter's primary concern... If true basic auth / api key auth were in play and not just cookie auth, it'd be a different story. One would think simply introducing basic auth to the admin portal would have been an agreeable compensating control until a proper long term solution could be designed and tested.
You're right, no point in obfuscating a private IP. So I add the -p 192.168.1.233:8089:8089 option to the run command.
It ran. I can access the admin page at 192.168.1.233:8089 (I had to authenticate first) from the Linux machine that the Docker container is running, and I can access from a browser on another machine on the local network (after authenticating), but I still can not connect from the AppleTv client.
- What version of Docker are you using?
- What version of Ubuntu are you using?
- Are you running Ubuntu on a physical server?
- What are the exact arguments that you're using to run that aren't working?
- Are you running more than one DVR on your system?
As I understand it, it's not about misconfiguring iptables, but rather a bug and vulnerability in Docker's bridged networking implementation and how it interacts with iptables. Meaning, this is to mitigate a security issue.
When someone runs a Docker container on a Docker host that does not have the proper iptables configuration to setup reverse NAT, the docker container will receive the IP address of the gateway as the source address for all packets. This is not done via a proxy that adds headers, it's done as simple TCP/UDP packet forwarding.
This means that the Docker container cannot tell what the source IP is at all. All connections appear to be coming from the same local IP (the gateway of the Docker container).
If someone exposes this container to the internet by setting up their router to manually forward a port to the container, all connections, locally or remotely, all appear they're coming from the local Docker gateway address and there is no way to get the real IP.
We have no way to accommodate this deployment while also ensuring that installations are not accessible publicly without authentication.
Thanks for the heads-up announcement and explanation of the issue.
- Docker 24.0.7
- Ubuntu 22.04
- Yes, Ubuntu is running on a Dell laptop
- Docker CLI command:
docker run \
--env=PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin \
--name=channels_dvr_8089 \
--network=host \
--volume=/home/scott/channels-dvr:/channels-dvr \
--volume=/media/scott/dvr_data:/shares/DVR \
--env=TZ=America/Chicago \
--restart=unless-stopped \
--runtime=runc -d fancybits/channels-dvr:tve
When I run this docker command, I am not able to connect to the Channels DVR admin page at localhost:8089/admin
- I do have another DVR running in network host mode on an Unraid server. I am able to access this DVR instance and connect from my AppleTV client.
Thanks for the help.
@runithome Are you trying to work around something to add that PATH=? It should not be needed.
What happens when you try to connect?
Are you able to submit diagnostics from the DVR that you're having trouble with?
I removed the PATH line. Thanks.
But I am still in the same situation:
If I start the Docker not in hosted mode and specify the port, I can access the DVR admin page on localhost, but the AppleTV client cannot connect. The logs on the server do not show anything when trying to connect with the AppleTV.
If I start the Docker in network hosted mode, I can not connect to the DVR admin page or connect with AppleTV.
Thanks for any suggestions.
Yes, I submitted logs as d5a3e4b5-3dc3-452c-8263-00ae5885df62
@runithome It looks like you have some funny things going on with the firewall on your system. I see some "network is unreachable" errors that I suspect is coinciding with when you switched to host networking. Considering you said you're running Ubuntu (and not Synology) you should have a system that can properly modify the iptables rules to configure the reverse NAT to work.
I'm not certain about the --runtime=runc argument and if that's impacting your setup, but if you google for people running into NAT issues with your versions of ubuntu, docker and runtime, you may get to the bottom of it.
Stable release will be going out later today.
I added this to my docker container in Unraid for my 2nd DVR server. The port works - however when I click on WebUI from the Docker page for that specific docker, it only pulls up 8089 port.
You also need to change the published port for the container. Something like -e CHANNELS_PORT=8080 -p 8080:8080 will change the server's port, and the container's.
