@eric I am not familiar with Docker commands. I think I copied the basics of that command from this forum. So I did not use that —runtime=runc argument intentionally or with any design.
Is there a cleaner Docker CLI command that I should be using to install the Docker DVR container?
That is used to change the port channels-dvr listens on if you're using docker host networking.
If you're using docker bridged networking, you don't need it.
What does your docker run command look like.
Thanks for poking at this release before we released it fully!
