This is a weird bug that has just started to happen recently:
On certain channels (so far, CNBC, Discovery and Bravo) if I navigate in the Guide to the HD version of the channel and select RECORD, it will record exactly that program on that HD channel. BUT, if I instead select Create Pass, it will record the show but from the Standard Def channel.
For example, if I navigate to Channel 620 in the Guide which is the Discovery HD channel, choose a program and hit record, it will record from channel 620 and the recording will be in high def. But if I instead hit Create Pass, the DVR will instead record in Standard Def from Channel 1562, which is the Discovery East feed, even though I selected it from Channel 620.
Needless to say, I would much prefer to have my tv record in high def rather than SD.
Is there any way to stop this behavior?
