I've tried to record a couple series passes but I keep getting an error that they failed because the program already started. I tried to add a minute padding as well but it didn't help. If I record just a single episode I have not had any errors that way.
2019/12/05 14:57:26 [DVR] Rule 'Young Sheldon' (2) found 3 new airings
2019/12/05 14:57:26 [DVR] queued recording job for EP026422390053 @ Thu Dec 5 7:59:00PM (1575593940-2)
2019/12/05 14:57:26 [DVR] queued recording job for EP026422390054 @ Thu Dec 12 7:59:00PM (1576198740-2)
2019/12/05 14:57:26 [DVR] queued recording job for EP026422390038 @ Thu Dec 19 7:59:00PM (1576803540-2)
2019/12/05 14:57:26 [DVR] Waiting 5h1m33.6172722s until next job 1575593940-2 Young Sheldon
2019/12/05 15:18:50 [CACHE] Deleted cache for already deleted file 3
2019/12/05 15:18:50 [CACHE] Deleted cache for already deleted file 4
2019/12/05 19:31:31 [CACHE] Deleted cache for already deleted file 3
2019/12/05 19:31:31 [CACHE] Deleted cache for already deleted file 4
2019/12/05 19:58:16 [TNR] Opened connection to 10764929/0 for ch8.1 WJW FOX
2019/12/05 19:58:16 [HLS] Starting transcoder for channel 8.1 from fe80::cda4:d2ab:c0ed:e8e2%Ethernet (encoder=libx264, resolution=1080, deinterlacer=blend, bitrate=10000)
Error while decoding stream #0:2: Invalid data found when processing input
Error while decoding stream #0:1: Invalid data found when processing input
[aac @ 000000000265a400] Queue input is backward in time
[aac @ 000000000261e780] Queue input is backward in time
[hls @ 000000000261f9c0] Non-monotonous DTS in output stream 0:1; previous: 4800, current: 3840; changing to 4801. This may result in incorrect timestamps in the output file.
[hls @ 000000000261f9c0] Non-monotonous DTS in output stream 0:2; previous: 5297, current: 4337; changing to 5298. This may result in incorrect timestamps in the output file.
[mpegts @ 000000000261bcc0] Dropped corrupted packet (stream = 1)
[mpegts @ 000000000261bcc0] Dropped corrupted packet (stream = 0)
Error while decoding stream #0:1: Error number -16976906 occurred
[mpegts @ 000000000261bcc0] Dropped corrupted packet (stream = 2)
Error while decoding stream #0:2: Error number -16976906 occurred
Last message repeated 1 times
[ac3 @ 00000000026227c0] expacc 126 is out-of-range
[ac3 @ 00000000026227c0] error decoding the audio block
2019/12/05 20:05:01 [HLS] Stopping inactive session ch8.1-dANY-ipfe80--cda4-d2ab-c0ed-e8e2-Ethernet @ 7m3.106022s
2019/12/05 20:05:01 [TNR] Closed connection to 10764929/0 for ch8.1 WJW FOX
2019/12/05 20:14:49 [DVR] Skipping job because program already started 1575593940-2 Young Sheldon
2019/12/05 23:44:12 [CACHE] Failed to delete cached for 2: remove F:\dvr\Channelsdvr\Streaming\cache\2\transcoder.log: The process cannot access the file because it is being used by another process.
