Setting up future "Series Pass" for TV shows further than the 14 days of EPG data
Is it possible to setup future "series pass" recordings outside of the 14 day EPG data? A number of TV shows I would like to record are due to be aired in the next couple of months. I tried a "search" within the Channels app, but nothing shows up (assuming this is because the show is not yet listed within the EPG data). Is there anyway to setup a "series pass" for TV shows outside of the 14 day EPG listings? This would be great if possible!
An advanced based that matches the name would be simplest
Thanks for the reply. How would i go about setting this up? Do i set this up via the server, or can it be done in the android / fire tv app?
Via the server
Here's an example of one I did for recording movies that may show up from time-to-time. Worked in recording a couple of movies when they became available:
Advanced passes are very powerful.
You can see examples of advanced passes in the forum Playground > Advanced Passes
This is great, exactly what I have been looking for. Are there any advanced filters / condition for language?
Unfortunately, no filter on language.
However, you could filter out a channel that shows programs in another language. Either by disabling the channel from your guide completely or with an active filter in the pass itself with the condition "Channel EXCLUDES 1234" (replace with actual channel number).
Ok great, thanks for the help.
Can I ask - My channels from satellite are blind scans (FTA) & then I setup "favourite channels" within the Channels DVR server. When I'm setting up an advanced series pass, is the search result based on all channels or limited to my favourites?
All channels.
Thanks - This feature is very useful!
